ken.mayfield Posted March 2, 2012 Share Posted March 2, 2012 I'm on 64bit Win vista 1) run heaven_d3d9.bat 2) once the demo starts, open console 3) type editor_load 4) fly through the ground until you can see the moving/floating rocks underneath 5) try to select a moving rock, a closer mesh will be selected instead 6) delete that mesh 7) repeat until you can select the moving rock 8) open node editor window 9) select the parent node of the selected moving rock in the node list 10) crash let me know if you need more info Link to comment
watchvombat Posted March 11, 2012 Share Posted March 11, 2012 Hi! Can you specify please: 5) try to select a moving rock, a closer mesh will be selected instead 6) delete that mesh do you delete the whole island or only the rock on the step 6)? Also, can you attach log.html file with crash? Thanks Link to comment
ken.mayfield Posted March 21, 2012 Author Share Posted March 21, 2012 I just remember trying to quickly select the rock quickly and deleting everything that was in my path. I'll try again soon and get this info. Link to comment
