manuel.gysin Posted February 19, 2012 Share Posted February 19, 2012 Hello Had a strange problem today with the output while using strings. After some searching in the code, I couldn't find any logic problems but a "bug" or not so a nice behavior of the engine. When declaring a local variable in a method, this variable is re-used with all information associated when the method is called a second time or a third. class TestLog { void print(string _string) { string arg; // The old memory is used and not cleaned after the first call arg = arg + _string; // This line is the problem while the old information is still in arg log.error(arg + "\n"); } }; TestLog logger; int init() { logger = new TestLog(); return 1; } int update() { logger.print("Hello! "); return 1; } int shutdown() { return 1; } When executing this code, the output should be: 23:05:21 Hello! 23:05:21 Hello! 23:05:21 Hello! The local variable should be deleted and cleaned up after the method is left. But the real output is: 23:05:21 Hello! 23:05:22 Hello! Hello! 23:05:22 Hello! Hello! Hello! 23:05:22 Hello! Hello! Hello! Hello! 23:05:22 Hello! Hello! Hello! Hello! Hello! 23:05:22 Hello! Hello! Hello! Hello! Hello! Hello! 23:05:22 Hello! Hello! Hello! Hello! Hello! Hello! Hello! 23:05:22 Hello! Hello! Hello! Hello! Hello! Hello! Hello! Hello! 23:05:22 Hello! Hello! Hello! Hello! Hello! Hello! Hello! Hello! Hello! kind regards Manuel Link to comment
Guest anet Posted February 20, 2012 Share Posted February 20, 2012 It is a Unigine script feature :). Local variables are static. See here: https://developer.un...features#scopes If you do not want to accumulate arg variable inside print function, you should clear it before usage: class TestLog { void print(string _string) { string arg = ""; arg = arg + _string; log.error(arg + "\n"); } }; 1 Link to comment
manuel.gysin Posted February 20, 2012 Author Share Posted February 20, 2012 It is a Unigine script feature :). Local variables are static. See here: https://developer.un...features#scopes If you do not want to accumulate arg variable inside print function, you should clear it before usage: class TestLog { void print(string _string) { string arg = ""; arg = arg + _string; log.error(arg + "\n"); } }; Hello Anet Thanks for the information. Strange never noticed this! I fixed it like you wrote it, but it is still strange for me. For optimal memory usage, I have to delete in this case all variables declared and initialized in a method at the end. kind regards Manuel Link to comment
