powerspeed_de Posted December 2, 2011 Share Posted December 2, 2011 volumetric object при приближении становится виден сквозь объекты с которыми он пересекается. параметры смешивания материала не влияют на этот глюк. это баг или это можно как-то настроить? volumetric object becomes visible when approaching through the objects with which it intersects. Blending parameters does not influence this glitch. this is a bug or is it possible to configure? Link to comment
frustum Posted December 4, 2011 Share Posted December 4, 2011 Reduce the near clipping plane. Link to comment
powerspeed_de Posted December 5, 2011 Author Share Posted December 5, 2011 Reduce the near clipping plane. Thank you, decrease the value of near clipping solves the problem Link to comment
