Is Front Face Node
Outputs a boolean value indicating which polygon face is surrently rendered, front (True) or back (False). You can pass this value to a Branch node to change the look of your material for back faces of polygons. This functionality is available only when the Two Sided option is enabled for the material, otherwise backfaces of polygons simply won't be visible.
Last update: 2021-12-13
