carl.sutton Posted November 3, 2011 Share Posted November 3, 2011 Hello, I have found that both my own code that calls engine.editor.saveMesh function and the mesh export button in the editor will cause unigine to crash and will fail to make a combined mesh file when trying to export using ObjectMeshDynamic nodes that have more than one surface. Just to make sure I havn't done anything stupid, here is the code I used to make my multi surface dynamic object which then refuses to export to a mesh; ObjectMeshDynamic CreateCylinder(ObjectMeshDynamic mesh,float radius,float height, vec4 texCoord, int stacks = 1,int slices = 32,Mat4 transform = Mat4_identity) { height /= 2.0f; float k = floor(PI * radius / height); Mat4 rtransform = rotation(transform); mesh.addFan(slices + 2); mesh.addVertex(transform * vec3(0.0f,0.0f,height)); mesh.addTexCoord(vec4(0.5f,0.5f,0.0f,0.0f)); mesh.addNormal(rtransform * vec3(0.0f,0.0f,1.0f)); for(int j = 0; j <= slices; j++) { float s = float(j) / slices; float theta = PI2 * s - PI05; vec3 normal = vec3(cos(theta),sin(theta),0.0f); mesh.addVertex(transform * (vec3(0.0f,0.0f,height) + normal * radius)); mesh.addTexCoord(vec4(normal.x * 0.5f + 0.5f,0.5f - normal.y * 0.5f,0.0f,0.0f)); mesh.addNormal(rtransform * vec3(0.0f,0.0f,1.0f)); } mesh.addFan(slices + 2); mesh.addVertex(transform * vec3(0.0f,0.0f,-height)); mesh.addTexCoord(vec4(0.5f,0.5f,0.0f,0.0f)); mesh.addNormal(rtransform * vec3(0.0f,0.0f,-1.0f)); for(int j = 0; j <= slices; j++) { float s = float(j) / slices; float theta = PI2 * s - PI; vec3 normal = vec3(sin(theta),cos(theta),0.0f); mesh.addVertex(transform * (vec3(0.0f,0.0f,-height) + normal * radius)); mesh.addTexCoord(vec4(normal.x * 0.5f + 0.5f,normal.y * 0.5f + 0.5f,0.0f,0.0f)); mesh.addNormal(rtransform * vec3(0.0f,0.0f,-1.0f)); } mesh.addSurface("end"); //SURFACE 1 int num_vertex = mesh.getNumVertex(); for(int i = 0; i < stacks; i++) { for(int j = 0; j < slices; j++) { int offset = num_vertex + (slices + 1) * i + j; mesh.addIndex(offset + 0); mesh.addIndex(offset + slices + 1); mesh.addIndex(offset + 1); mesh.addIndex(offset + slices + 2); mesh.addIndex(offset + 1); mesh.addIndex(offset + slices + 1); } } for(int i = 0; i <= stacks; i++) { float t = float(i) / stacks; for(int j = 0; j <= slices; j++) { float s = float(j) / slices; float theta = PI2 * s - PI05; vec3 normal = vec3(cos(theta),sin(theta),0.0f); mesh.addVertex(transform * (vec3(0.0f,0.0f,height - height * t * 2.0f) + normal * radius)); //mesh.addTexCoord(vec4(s * k,t,0.0f,0.0f)); mesh.addTexCoord(vec4(texCoord.x,lerp(texCoord.y, texCoord.w, t),0.0f,0.0f)); //FIXME texcoords are incorrect mesh.addNormal(rtransform * normal); } } mesh.addSurface("body"); //SURFACE 2 mesh.updateBounds(); mesh.updateTangents(); return mesh; } }; I have tried the above code without making it multi surfaced and the problem does not occur. It will be much appreciated if a fix could be found for this as I would prefer not to have to make a seperate mesh for each surface or use some other workaround that converts dynamic to a node type that will export. Thanks Link to comment
frustum Posted November 3, 2011 Share Posted November 3, 2011 Thanks, that will be fixed in the next SDK. Link to comment
