[SOLVED] 2.19 Can't change CIGI View FOV with Spidervision viewport
I'm using the technique described earlier to have multiple viewport in a single instance, each showing a specific CIGI View.
sv->setViewportCustomPlayer(viewport->getID(), view->getPlayer());
But this doesn't allow to change the view FOV (CIGI ViewDefinition have no effect). I looks like the setViewportCustomPlayer player FOV is ignored or overwritten by SpiderVision.
How can I fix that?
Duh, my bad.
The issue here was I had projection_enabled="1" in the spider configuration file.
Changing it to "0" fixes this, and I'm now able to change the FOV as expected through CIGI.
  • Amerio.Stephane changed the title to [SOLVED] 2.19 Can't change CIGI View FOV with Spidervision viewport
