Lales.Charles Posted February 7 Posted February 7 Hi, I do have a weird issue: - I create a new project with VR/IG template (SDK 2.19.1.2, default \data\.editor2\sandworm\urls.json) - Tool > sandworm > create new named "terrain" - UI briefly opens then closes - Afterwards Tool > sandworm doesn't do anything - I do have to del terrain.sworm, restart editor, then I can create new one It just generates one warning: Source data (background) is out of the projection (EPSG:25832) boundaries This issue occures on laptop (Dell Mobile Precision Workstation 7780 with i9-13950HX, 64GB DDR 5, 2TB SSD and RTX 4090 mobile) but not on workstation (Dell Precision 3680 with i9-14900K, 64GB DDR5, 2TB and RTX 4090). Would you have any clue what is going on? Regards,
bmyagkov Posted February 7 Posted February 7 Hello @Lales.Charles This issue is most likely caused by corrupted Editor configuration files which can be found at: C:\Users\%USERNAME%\AppData\Local\unigine\Editor Deleting the entire folder should resolve the problem. Could you give it a try and let us know the results? Thanks! 1
Lales.Charles Posted February 7 Author Posted February 7 Hi, Excellent, solved! No idea how I corrupted this files.. but good to know! Regards, Charles 1
