Is a node/volume visible?
We have multiple nodes with some heavy components inside (with render to texture, etc). Is it possible, in the update call of these components, to check if the node they are modifying is visible at all (or was visible recently)? Is there any way to use a surface LOD visibility to check if the surface is actually significant/visible?
Hi Stephane,
There is a method called isVisibleCamera from the Object class that seems to do what you need: https://developer.unigine.com/en/docs/2.19.1/api/library/objects/class.object?rlang=cpp#isVisibleCamera_int
It's quite fast so you can use it without any worries. Unless you need to check thousands of objects per frame :)
  • Thanks 1
