Unity import Sence plugin error
Go to solution Solved by fox,
  • Solution
Hi, @perfectsummer
Seems like you're trying to use the 2.19 version of the plugin with UnigineEditor 2.19.1 (as seen in the video you provided). Try downloading the UnityImporter addon for SDK 2.19.1  https://store.unigine.com/add-on/1eefdaff-41c4-6b10-ace6-6b87a2ef1d21/description.
After installing the proper 2.19.1 version, the plugin shall appear in the Tools menu.
Hope this helps!
Thank you!
13 hours ago, fox said:
你好,@perfectsummer
似乎您正在尝试将 2.19 版本的插件与 UnigineEditor 2.19.1 一起使用(如您提供的视频中所示)。尝试下载适用于SDK 2.19.1的UnityImporter插件:  https://store.unigine.com/add-on/1eefdaff-41c4-6b10-ace6-6b87a2ef1d21/description
安装正确的 2.19.1 版本后,插件将出现在工具菜单中。
希望这有帮助!
谢谢你!
OK, there were some minor problems, but it worked in the end. There was a cumbersome operation that the old package would not be overwritten after the plug-in package was imported. When I imported the plug-in version 2.9 and imported 2.9.1 again, the file was not overwritten, but I had to go to the folder directory to manually delete the original file before the import took effect againimage.png.ed01d705f0ed2a1bde8948c1fb18726d.png
