2.19 IG Aviation TerrainSurfaceSettings missing landscape mask fetch
In 2.19 (maybe since 2.18?), the addon IG Aviation/TerrainSurfaceSettings is missing the query of the landscape mask. (was in line 53 of TerrainSurfaceSettings.cpp)
		for (auto &it : landscape_info)
			float v = landscape_fetch->getMask(it.mask); // find the most intense mask
			if (v > max_value)
				if (ret_info)
					ret_info->normal = landscape_fetch->getNormal();
					ret_info->point = pos;
					ret_info->point.z = landscape_fetch->getHeight();
					ret_info->object = landscape;
					//ret_info->landscape_mask = it.mask; // NO LONGER HERE in 2.19 code...
				max_value = v;
				ret = it.type;
How can we retrieve this back?
Hi Stephane,
We have reviewed earlier versions of the IG Aviation add-on (starting from 2.16) and could not locate any code that returns landscape mask data.
Is there a possibility that you manually modified this code in version 2.16 and have been using it consistently since then? If so, you will need to restore it in version 2.19.1 and continue using it as you did previously.
