Amerio.Stephane Posted yesterday at 06:48 PM Share Posted yesterday at 06:48 PM Hello, this one took me a while to isolate... Create a new 2.19 IG+VR cpp template (the VR part seems important...), with SpiderVision and Syncker Add IG, SpiderVision, Syncker on the start up command line Start the app, press F10 and create a default.sv file in /data set console_onscreen 1 Restart the app The console will dump a constant stream of ERROR: Camera::setProjection: invalid projection matrix. Apparently, the default.sv <viewport> section contains this attribute head_pos_offset="0 2.08999991 0" which create this stream of error. Removing it fix the problem, until a new sv needs to be created... Sub-question: What is this for? Link to comment
