2.19: -sync_view option removed
Apparently, the -sync_view command line option has been removed (but is not listed in the console migration guide).
I use it to select the start up view ID on the command line (more versatile than modifying the ig_config.xml/IG/default_view_id).
Also, in 2.18 igManager->getSynckerName() used to report the value passed to -sync_view.
How do I get something similar: being able to set the startup CIGI view ID, and getting it back in code.
Do I need to use SpiderVision to get something similar? What if some instances in a cluster don't use it?
Yes you are right, the -sync_view parameter has been removed. Now this functionality is provided by SpiderVision plugin via the -computer_name parameter on startup, as well as via the API function SpiderVision::Manager::(set/get)ComputerName in runtime
