Cant create jpg
Iam trying to create a flowmap jpg however i get this error whenever i try to create the texture in the "Texture Paint Mode",or "Surface Custom Texture".It gives this error for any format i try to create.A work around is to make a blank jpg in gimp then import it into the asset browser,and i can paint on it with no issue.
Win 10 and Editor 2.19.0.1
Project Type C++ & Directx 12
ImageLoaderJPG::save(): can't save RGBA8 format into the "C:/Users/llll/Documents/UNIGINE Projects/unigine_project/data/textures/deasg.jpeg" file
ImageLoaderJPG::output_message(): Empty input file
ImageLoaderJPG::load(): can't load "C:/Users/llll/Documents/UNIGINE Projects/unigine_project/data/textures/deasg.jpeg" file
C:/Users/llll/Documents/UNIGINE Projects/unigine_project/data/textures/img1.jpeg (0B): import started...
C:/Users/llll/Documents/UNIGINE Projects/unigine_project/data/textures/img1.jpeg: import finished in 5.101000 ms
ImageLoaderJPG::load(): can't load "C:/Users/llll/Documents/UNIGINE Projects/unigine_project/data/textures/img1.jpeg" file
C:/Users/llll/Documents/UNIGINE Projects/unigine_project/data/textures/deasg.jpeg: import finished in 5.252000 ms
"ImportTextureStage: Image file saving error. (Source filepath: C:/Users/llll/Documents/UNIGINE Projects/unigine_project/data/textures/img1.jpeg)"
Edited by jyhdyjguf
There is no way to store RGBA data inside a JPEG file (it only can handle up to 3 channels - RGB). Please try to use different file format.
For flowmap I think it would be enough to have 2 channels (RG).
  • Thanks 1
Any file format either .jpeg,.jpg,exr,etc or any channels RG,RGB,etc,or any depth all result in that exact error i posted i cant create any image file in the editor
When i browse my project in windows file explorer i can see all the image files i tried to create in the editor,however all the image files are 0 bytes.
the issue is the editor will not generate a valid image file regardless if its meant for a flow map or not.
tt.thumb.png.cfd84ad7557858b254c882a37b8740b1.pngaa.thumb.png.55bcb68973340b546768f6f21a5d3cd5.pngcc.thumb.png.e403e6f67c6b3fc30894541545ad32db.png
No file called texture.jpg shows up in asset browser
But it creates a empty jpg file in windows directory
What ive tried
  • Unchecking read-only on the project folder
  • Adding project folder exclusion to anti virus
  • windows user account has full control over project folder(Read,write,etc)
  • Tried previous sdk 2.18
Ok it was user error @silent and @dosma told me the answer i didnt read it correctly sorry about all that thanks
