AaronBerney Posted Thursday at 06:32 PM Share Posted Thursday at 06:32 PM Since installing the 2.19 SDK I can't see my plugins in the Editor Plugin Manager, seemingly in any projects, 2.18 or 2.19. The plugin in my actual project, now upgraded to 2.19, no longer shows its plugin, and I've tried creating an empty project with a new plugin, both 2.18 and 2.19, or adding a plugin to an existing 2.18 project. I can build the projects fine, but the just won't show up in the plugin manager. Any ideas? Many thanks... Link to comment
arizmenda Posted 20 hours ago Share Posted 20 hours ago Hi, Aaron! So far, I can see this issue occur if the plugin version does not match the version of the upgraded project. Can you attach the editor_log.txt from bin folder? Will the behavior repeat if you use different plugins, from our add-on store, for instance? If so, can you describe in detail how to reproduce the problem on our side. Thanks! Link to comment
