parthip Posted Wednesday at 02:00 AM Share Posted Wednesday at 02:00 AM I have been making a first person controller and i am trying to clamp the camera movement in y direction so that it doesn't turn 360 degrees given below is the code how do i implement it and i a using unigine version 2.15 #include "movement.h" #include <UnigineGame.h> #include <UnigineEditor.h> REGISTER_COMPONENT(movement); // macro for component registration by the Component System void movement::init() { _playerManager = getComponent<playerManager>(node); Player = _playerManager->getPlayer(); } void movement::updatePhysics() { float speed = speedW; float ifps = Game::getIFps(); float mouse_delta_x = Input::getMouseCoordDelta().x; float mouse_delta_y = Input::getMouseCoordDelta().y; // Calculate the rotation based on mouse movement and sensitivity float rotation_x = mouse_delta_x * sensitivity * ifps; float rotation_y = mouse_delta_y * sensitivity * ifps; // Rotate the node on the X-axis (yaw) if (node) { quat current_node_rotation = node->getWorldRotation(); quat yaw_rotation = quat(Vec3_up, -rotation_x); quat new_node_rotation = yaw_rotation * current_node_rotation; node->setWorldRotation(new_node_rotation); } // Rotate the camera on the Y-axis (pitch) if (camera) { quat current_camera_rotation = camera->getWorldRotation(); Vec3 right_direction = current_camera_rotation * Vec3_right; quat pitch_rotation = quat(right_direction, -rotation_y); quat new_camera_rotation = pitch_rotation * current_camera_rotation; camera->setWorldRotation(new_camera_rotation); } currentState = _playerManager->getCurrentState(); currentPose = _playerManager->getCurrentPose(); if (currentPose == _playerManager->MOVEMENTPOSE::running) { speed = speedR; } else { speed = speedW; } switch (currentState) { case _playerManager->MOVEMENTSTATES::Forward: movementDirection = node->getWorldDirection(Unigine::Math::AXIS_Y); Player->addLinearImpulse(movementDirection*speed*ifps); break; case _playerManager->MOVEMENTSTATES::Backward: movementDirection = node->getWorldDirection(Unigine::Math::AXIS_NY); Player->addLinearImpulse(movementDirection*speed*ifps); break; case _playerManager->MOVEMENTSTATES::LeftStride: movementDirection = node->getWorldDirection(Unigine::Math::AXIS_NX); Player->addLinearImpulse(movementDirection*speed*ifps); break; case _playerManager->MOVEMENTSTATES::RightStride: movementDirection = node->getWorldDirection(Unigine::Math::AXIS_X); Player->addLinearImpulse(movementDirection*speed*ifps); break; case _playerManager->MOVEMENTSTATES::Jump: movementDirection = node->getWorldDirection(Unigine::Math::AXIS_Z); Player->addLinearImpulse(movementDirection*speed*ifps); break; default: break; } } 1 Link to comment
parthip Posted Thursday at 12:41 PM Author Share Posted Thursday at 12:41 PM The current code given above doesn't clamp the camera rotation vertically so can anyone help me with it ? Also the the fall of the character is slow after jumping, the acceleration of gravity is -9.8 . What should I do to rectify this problem? Link to comment
cash-metall Posted 21 hours ago Share Posted 21 hours ago It's difficult to pinpoint the exact issue without all the source code and a clear understanding of the hierarchy between the Player and the Node. However, here are a few suggestions: The updatePhysics method is called at a framerate different from the game loop, so using Game::IFps in this function is incorrect, as is applying transformations to nodes directly within the physics update. It's better to move the code responsible for adjusting the camera position to the post_update method. It's also best not to mix the setTransform/Rotation approach with applying physics to the same object. Doing so can lead to issues with physics (such as preserving momentum, acceleration) due to the object constantly being "teleported" to another position. Currently, it's unclear whether the Player and Node are separate nodes and what their dependency is, but the "slowing" effect in physics is usually related to mixing these approaches. By separating direct transformations and physics operations, you'll likely avoid conflicts in behavior. 1 Link to comment
parthip Posted 16 hours ago Author Share Posted 16 hours ago Thank you @cash-metall for your suggestions. as you said I have separated rotation and physics into different component and the camera component as been added to the camera node, also i create node(dirNode) for getting the direction for the WASD movement ,now i am not rotating the player which is a rigid body instead the dirNode for the yaw and the camera for the pitch. // Rotate the node on the X-axis (yaw) if (dirNode) { quat current_node_rotation = dirNode->getWorldRotation(); quat yaw_rotation = quat(Vec3_up, -rotation_x); quat new_node_rotation = yaw_rotation * current_node_rotation; dirNode->setWorldRotation(new_node_rotation); } // Rotate the camera on the Y-axis (pitch) if (node) { quat current_camera_rotation = node->getWorldRotation(); Vec3 right_direction = current_camera_rotation * Vec3_right; quat pitch_rotation = quat(right_direction, -rotation_y); quat new_camera_rotation = pitch_rotation * current_camera_rotation; node->setWorldRotation(new_camera_rotation); } This the hierarchy for the player node But the rotation of the camera in the y-axis if not limited i.e. it rotates 360 degrees, how to stop that or clamp it? Link to comment
