Amerio.Stephane Posted September 4 Share Posted September 4 Hello, Something is not working as expected (or at least, I don't understand the current behaviors). SDK 2.18.1 On master, syncker->loadNode("test.obj") will produce a bunch of WARNING: Move immovable node: "default" This happens during the loadNode, even before I even try to move the loaded node. (the loading itself work). As I may want to move the node around, I will setImmovable(false) on all of the node hierarchy anyway. On master, syncker->loadNode("othertest.node") works correctly and the node position is not syncked to slaves (as expected). But syncker->loadNode("othertest.node", Plugins::Syncker::Master::BASE) forces continuously the object position at 0,0,0, quite unexpectedly. So I can't move the node at all. This one is quite blocking at the moment. Link to comment
cash-metall Posted September 5 Share Posted September 5 Hello! 1. At the moment, there is no way to bypass this issue when loading OBJ files. In this case, we recommend either using .node files or simply suppressing the warning by using: World::setMovingImmovableNodeMode(World::MOVING_IMMOVABLE_NODES_MODE_ALLOW); 2. loadNode(path, BASE) works as expected. The BASE flag does not assume that the node will move, and its transformation is not synchronized. To synchronize the position, you need to set the TRANSFORM flag: master->loadNode(path, Plugins::Syncker::Master::BASE & Plugins::Syncker::Master::TRANSFORM); However, if the position only needs to be set once, you can use the third argument: master->loadNode(path, 0, init_transform); This is useful for creating a static object without further synchronization. Link to comment
Amerio.Stephane Posted September 5 Author Share Posted September 5 Quote At the moment, there is no way to bypass this issue when loading OBJ files. In this case, we recommend either using .node files or simply suppressing the warning by using: World::setMovingImmovableNodeMode(World::MOVING_IMMOVABLE_NODES_MODE_ALLOW); This is an acceptable workaround at the moment. But is it an overlook in the implementation (meaning we should have a way to specifiy movable/immovable per object when importing not-a-node). I don't remember having this kind of issue in 2.16 Quote loadNode(path, BASE) works as expected. The BASE flag does not assume that the node will move, and its transformation is not synchronized. To synchronize the position, you need to set the TRANSFORM flag Now I don't understand, because the documentation and your header specifically states the contrary: https://developer.unigine.com/en/docs/2.19/api/library/plugins/syncker/class.syncker_master?rlang=cpp SYNC_MASK Node synchronization mask. Name Description NODE_FLAGS = 1 Update only simple node flag (enabled, etc.) TRANSFORM = 1 << 1 Update node transform (with interpolation). BASE = 3 Update base information NODEFLAGS & TRANSFORM. So BASE should definitively include TRANSFORM. Or something is broken (doc or code). If not, what should be the behavior of TRANSFORM only? What if we need to sync also the enabled state? And what does BASE sync exactly then, compared to NODE_FLAGS? On a side note, thanks for reminding that I can also set just the initial transform, that can also be helpful! Link to comment
cash-metall Posted September 6 Share Posted September 6 Yes, you're right, BASE does include TRANSFORM! That was my mistake - I rushed to answer without checking the enum properly. I tried to reproduce the issue based on the SynckerDemo, specifically in the third example: LoadNode void MasterLogic3::on_button_clicked() { // transform Vec3 pos = Vec3( Game::getRandomFloat(-5.0f, 5.0f), Game::getRandomFloat(-10.0f, 0.0f), Game::getRandomFloat(5.0f, 15.0f)); quat rot = quat( Game::getRandomFloat(0.0f, 360.0f), Game::getRandomFloat(0.0f, 360.0f), Game::getRandomFloat(0.0f, 360.0f)); // spawn node last_node = master->loadNode(spawn_node, Syncker::Master::BASE); last_node->setWorldPosition(pos); last_node->setWorldRotation(rot); } It looks like everything is working as expected. Which version of the SDK are you using? (UPD i see 2.18, its also work for 2.18) Link to comment
Amerio.Stephane Posted September 6 Author Share Posted September 6 Indeed, it works in the sample; So... I rolled a quick sample test and here is my finding: the first call(s) to setPosition are simply ignored. int AppWorldLogic::init() { Mat4 mat; mat.setTranslate({ 0,0,5 }); //<---- This transform is actually applied auto s = Syncker::Manager::get()->getMaster(); node = s->loadNode("Box.node", Syncker::Master::BASE, mat); node->setWorldPosition({ 5,0,5 }); //<---- this call has no effect return 1; } If then I call setWorldPosition in the update loop, then it will work. Feels very strange to me. Link to comment
Amerio.Stephane Posted September 10 Author Share Posted September 10 Could you reproduce this bug with the code above? We're stuck on this, and it was working flawlessly in 2.16... Link to comment
silent Posted Wednesday at 04:50 AM Share Posted Wednesday at 04:50 AM So far we have no luck with reproduction, everything is working fine (setWorldPosition is being applied correctly). But we are still continue our attempts :) How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Amerio.Stephane Posted Wednesday at 08:28 AM Author Share Posted Wednesday at 08:28 AM Here is attached a quick sample, showing the surprising behavior. Output here is: 09:54:30 Master::init(): waiting for 0 slaves... 09:54:30 After loadnode: 1 (expected: 1) 09:54:30 After setwpos: 1 (expected: 2) 09:54:30 Master::wait_connections(): Starting session... 09:54:30 After update: 2 (expected: 3) 09:54:30 Master::session_starting(): session started 09:54:30 After update: 1 (expected: 3) 09:54:30 After update: 3 (expected: 3) 09:54:30 After update: 3 (expected: 3) 09:54:30 After update: 3 (expected: 3) Rationale: we need to spawn a node at a precise location lat&lon, but the altitude and orientation depends of the object itself, so we must spawn it and then reorient and move it (it's moved both after being spawn and measured, and later it may also be moved by a component in the spawned node). With 2.18, the object is not correctly relocated after being spawn, as the first calls to setWorldPosition have no effect. test_loadnode.zip 1 Link to comment
silent Posted Wednesday at 08:40 AM Share Posted Wednesday at 08:40 AM Thank you; it is now clearer. Now we got a stable repro and I believe we would provide a patch by the end of the week. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
silent Posted Wednesday at 12:53 PM Share Posted Wednesday at 12:53 PM Fixed test_loadnode: AppWorldLogic.cpp How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
