aleksandar.kordic Posted October 13, 2011 Share Posted October 13, 2011 Hi all, My intent is to integrate Unigine engine into existing multimedia framework. I hope this is the right place for this question. To make proof of concept application I need to find a way to load image/texture into engine. There is a Image class mentioned in script reference and in C++ API reference. I am guessing that Image object needs to be initialized with pixel data somehow. Only exposed methods are: int load(const char * name) int load(const char * name, int offset) The question is how to create image from pixel-data produced from external c++ code ? Is there some API function like `glTexImage2D` or `glTexSubImage2D` ? Link to comment
frustum Posted October 13, 2011 Share Posted October 13, 2011 There are two ways to achieve that: * Use of image->set2D(x,y,r,g,b,a) or image->set2D(x,y,Pixel) function. * Direct copying of image data via memcpy(image->getPixels2D(),source,image->getSize()); Link to comment
aleksandar.kordic Posted October 13, 2011 Author Share Posted October 13, 2011 Hi, I should use memcpy() because of HD content that needs to render 1920x1080 image at 60fps. Initialize with: int create2D(int width, int height, int format, int num_mipmaps) to specify image format and allocate pixmap buffer and then change pixel data directly. Because image->getPixels2D() returns pointer to the array of pixels. Thanks Link to comment
