steve3d Posted October 13, 2011 Share Posted October 13, 2011 I've successfully ported nvidia's fxaa shader to unigine. Because I have no knowledge of glsl, so, there is no opengl support, but I think some guys here have better knowledge of glsl, hope you can help me finish the shader. I just used a bad way to port this shader so the directx part are almost same except texture sampling, and I hope unigine can integrate it as a standard shader. add this material dedeclaration into data\core\materials\default\unigine_post.mat and save attachment shader to data\core\shaders\default\post and use it! use the shader files below. Link to comment
steve3d Posted October 13, 2011 Author Share Posted October 13, 2011 forgot to say, it's based on the first release of FXAA, I'm trying to port lastest fxaa 3.11 to unigine. Link to comment
ulf.schroeter Posted October 13, 2011 Share Posted October 13, 2011 Maybe there is a simpler way via tfarrar@nvidia.com, see Timothy Lottes blog on FXAA Game developers who want to check out a mixed DX9/DX11/OpenGL sample pack (includes source and white paper) can email me directly via tfarrar at NVIDIA. Link to comment
ulf.schroeter Posted October 14, 2011 Share Posted October 14, 2011 BTW I am quite sure that frustum will supply full Unigine FXAA version as he already implemented other post-processing-AA shaders quickly Link to comment
steve3d Posted October 14, 2011 Author Share Posted October 14, 2011 done, Ported FXAA ver 3.11, but still no opengl support, I don't know about glsl, sorry, material definition: tested a previous version on a scene, it maks fps drop about 20%, new shader on that scene only drops about %5 fps. I've heard that fxaa algorithm 3.12 will be released soon, hope this shader will get into standard unigine post shader. Link to comment
steve3d Posted October 14, 2011 Author Share Posted October 14, 2011 BTW, I can not figure out how to use #if preprocessor in this shader, tested with this pixel shader ##if TEST_VAL==3 return half4(0, 0, 0, 0); ##else return half4(0.5, 0.5, 0.5, 0.5) ##endif no matter how I define the TEST_VAL, the above code only return 0.5, it seems Parser.cpp has stripped the ##if preprocessor. or TEST_VAL=3 define Link to comment
steve3d Posted October 14, 2011 Author Share Posted October 14, 2011 final version, opengl and directx 9/10/11 all supported. don't have a ps3. waiting unigine guys to integrated into unigine. use this material def: <!-- /* Nvidia AntiAliasing filter material version 3 */ --> <material name="post_filter_fxaa"> <!-- states --> <state name="preset" type="switch" items="preset_10,preset_11,preset_12,preset_13,preset_14,preset_15,preset_20,preset_21,preset_22,preset_23,preset_24,preset_25,preset_26,preset_27,preset_28,preset_29,preset_39">3</state> <!-- shaders --> <shader pass="post" preset_defines="FXAA_QUALITY__PRESET_10,FXAA_QUALITY__PRESET_11,FXAA_QUALITY__PRESET_12,FXAA_QUALITY__PRESET_13,FXAA_QUALITY__PRESET_14,FXAA_QUALITY__PRESET_15,FXAA_QUALITY__PRESET_20,FXAA_QUALITY__PRESET_21,FXAA_QUALITY__PRESET_22,FXAA_QUALITY__PRESET_23,FXAA_QUALITY__PRESET_24,FXAA_QUALITY__PRESET_25,FXAA_QUALITY__PRESET_26,FXAA_QUALITY__PRESET_27,FXAA_QUALITY__PRESET_28,FXAA_QUALITY__PRESET_29,FXAA_QUALITY__PRESET_39" vertex="core/shaders/default/post/vertex_filter_antialiasing.shader" fragment="core/shaders/default/post/fragment_filter_fxaa3.shader"/> <!-- textures --> <texture name="color" pass="post" type="procedural"/> <!-- parameters --> <parameter name="fxaaQualitySubpix" type="slider" shared="1" min="0.0" max="1.0" flags="max_expand">0.75</parameter> <parameter name="fxaaQualityEdgeThreshold" type="slider" shared="1" min="0.063" max="0.333" flags="max_expand">0.166</parameter> <parameter name="fxaaQualityEdgeThresholdMin" type="slider" shared="1" min="0.0" max="0.0833" flags="max_expand">0.0625</parameter> </material> fragment_filter_fxaa3.shader Link to comment
frustum Posted October 14, 2011 Share Posted October 14, 2011 Thanks, we will try to integrate fxaa in the next SDK update. Link to comment
steve3d Posted October 15, 2011 Author Share Posted October 15, 2011 There is special render materials list (render.setRenderMaterials()) which is applied before post-processing. Link to comment
frustum Posted November 2, 2011 Share Posted November 2, 2011 This is a FXAA 2 (http://timothylottes...or-console.html) implementation. unigine_post.mat vertex_filter_antialiasing.shader fragment_filter_antialiasing.shader Link to comment
alexei.garbuzenko Posted November 12, 2011 Share Posted November 12, 2011 This is a FXAA 2 (http://timothylottes...or-console.html) implementation. I tested your shader and it seems to be much more blurry than steve3d implementation with exactly same performance impact. Of course it is much better than previous buggy 'post_filter_antialiasing' but I'd suggest using FXAA 3 instead. Link to comment
steve3d Posted November 13, 2011 Author Share Posted November 13, 2011 When I get home I'll try to modify shader to use #if preprocessor to improve performance. Link to comment
frustum Posted November 14, 2011 Share Posted November 14, 2011 I have made a new sample with fxaa 3.11 integration. This sample will available in the updated SDK on days. Link to comment
steve3d Posted November 14, 2011 Author Share Posted November 14, 2011 wow, that's quick, so this means I can wait then. Link to comment
steve3d Posted November 15, 2011 Author Share Posted November 15, 2011 done! using some defines actually boost a little performance. just use this shader. frustum, I have a question, now shader code support #if preprocessor, how should I use the value define in material definition, use this seems not work: preset_defines="FXAA_QUALITY__PRESET=10,FXAA_QUALITY__PRESET=11,FXAA_QUALITY__PRESET=12,FXAA_QUALITY__PRESET=13,FXAA_QUALITY__PRESET=14,FXAA_QUALITY__PRESET=15,FXAA_QUALITY__PRESET=20,FXAA_QUALITY__PRESET=21,FXAA_QUALITY__PRESET=22,FXAA_QUALITY__PRESET=23,FXAA_QUALITY__PRESET=24,FXAA_QUALITY__PRESET=25,FXAA_QUALITY__PRESET=26,FXAA_QUALITY__PRESET=27,FXAA_QUALITY__PRESET=28,FXAA_QUALITY__PRESET=29,FXAA_QUALITY__PRESET=39" shader complains no define of FXAA_QUALITY__PRESET fragment_filter_fxaa3.shader Link to comment
frustum Posted November 15, 2011 Share Posted November 15, 2011 It isn't possible to declare value of define in the material configuration file. Attached files will be presented in the SDK samples directory. post_filter_fxaa requires core post_filter_rgb2rgbl material. The list of render materials should be: "post_filter_rgb2rgbl,post_filter_fxaa". post_filter_fxaa.zip Link to comment
steve3d Posted November 15, 2011 Author Share Posted November 15, 2011 looks perfect, thats original fxaa shader, will be easier for later versions, thanks :) Link to comment
steve3d Posted November 15, 2011 Author Share Posted November 15, 2011 your zip packages lacks of post_filter_rgb2rgbl material.. :) Link to comment
alexei.garbuzenko Posted November 15, 2011 Share Posted November 15, 2011 frustum after all needed modifications I put you shader to /core/ directory and it works now. Speed is exactly the same as in steve3d latest shader. Overall image is somewhat more sharper. It would be great to see this shader built-in to next SDK. Also I tested your FXAA 2.0 shader once again and found it is slightly faster while having worse quality picture. I think we could use it as an option for medium quality settings. Link to comment
steve3d Posted November 15, 2011 Author Share Posted November 15, 2011 the image quality should be same, the only difference between my shader and frustum's is default parameter value and default preset. Link to comment
