Quaternion rotates by twice the angle
Good day,
I am confused because from the way I know this is the proper way of doing it:
    public quat angledAxis(float angle, vec3 rotationAxis){
        return new quat(rotationAxis, angle);
    public vec3 rotate(vec3 origin, vec3 point, quat angledAxis){
        quat q = angledAxis;
        vec3 v = point - origin;
        vec3 rotatedOffset = q * v * new quat(new float[] { -q.x, -q.y, -q.z, q.w });;
        return origin + rotatedOffset;
but for some reason rotatedOffset should be:
vec3 rotatedOffset = q * v;
So that when the same quat (angledAxis) is used 360 times it reaches to the starting position twice.
Shouldn't the quaternion be multiplied with this part?
so that the rotation is proper? Or am I missing something?
Edited by Sevdat
Hello.
If I understand correctly, you are trying to rotate a point relative to a given origin using a pure imaginary quaternion. In this case, the multiplication works incorrectly because you need to use quaternion multiplication instead of quaternion and vector multiplication. That is, we use the formula new_v = (q * v) * conjugate(q) as in the definition. The code will look like this:
vec3 rotateExplicit(vec3 origin, vec3 point, quat angledAxis)
	quat pureImaginaryQuaternion = new quat();
	pureImaginaryQuaternion.x = v.x;
	pureImaginaryQuaternion.y = v.y;
	pureImaginaryQuaternion.z = v.z;
	pureImaginaryQuaternion.w = 0.0f;
	pureImaginaryQuaternion = MathLib.Mul((MathLib.Mul(angledAxis, pureImaginaryQuaternion)), MathLib.Conjugate(angledAxis));
	vec3 rotatedOffset = new vec3(
		pureImaginaryQuaternion.x,
		pureImaginaryQuaternion.y,
The main difference is that in this version, the vector is converted into a quaternion. Then the multiplication works as expected: the distributive property and the rules of imaginary unit multiplication are used.
But you can simply use quaternion-vector multiplication from a math library. In it, the formula from the above example is already transformed:
	vec3 rotatedOffset = MathLib.Mul(angledAxis, v);
  • Sevdat changed the title to Quaternion rotates by twice the angle
