Sevdat Posted July 18 Share Posted July 18 (edited) Good evening, How can I create and remove joints by code? If I have 2 primitives how do I create a joint and then stop them from being a joint? I read the documentation, but I couldn't understand how to code it: https://developer.unigine.com/en/docs/future/api/library/physics/class.joint?rlang=cs&autotranslate=en#createJoint_int_Joint Edited July 18 by Sevdat Link to comment
bmyagkov Posted July 19 Share Posted July 19 6 hours ago, Sevdat said: Good evening, How can I create and remove joints by code? If I have 2 primitives how do I create a joint and then stop them from being a joint? I read the documentation, but I couldn't understand how to code it: https://developer.unigine.com/en/docs/future/api/library/physics/class.joint?rlang=cs&autotranslate=en#createJoint_int_Joint Hello! Have you had the opportunity to play with the "Joints" samples provided with the SDK? You can access them through the SDK Browser by following this path: "Samples -> UnigineScript -> Joints". These samples are made in UnigineScript but examining them could help you understand how it can be done through the code. Thanks! Link to comment
Sevdat Posted July 19 Author Share Posted July 19 (edited) 4 hours ago, bmyagkov said: Hello! Have you had the opportunity to play with the "Joints" samples provided with the SDK? You can access them through the SDK Browser by following this path: "Samples -> UnigineScript -> Joints". These samples are made in UnigineScript but examining them could help you understand how it can be done through the code. Thanks! Good day bmyagkov, First time looked into it now. The codes are C++, but that's not the issue.: I still can't find how the joint connections can be added and removed later. Edited July 19 by Sevdat Link to comment
Sevdat Posted July 19 Author Share Posted July 19 Good day, I think I figured it out: ObjectMeshDynamic clone; ObjectMeshDynamic clone2; Joint connectedJoint; public ObjectMeshDynamic createSphere(float radius,vec3 position,int i){ ObjectMeshDynamic sphere = Primitives.CreateSphere(radius, 9, 32); sphere.TriggerInteractionEnabled = true; sphere.SetIntersection(true, 0); sphere.SetIntersectionMask(1, 0); sphere.SetCollision(true,0); sphere.SetCollisionMask(1, 0); sphere.WorldPosition = position; sphere.Name = $"{i}"; BodyRigid bodySphere = new BodyRigid(sphere); new ShapeSphere(bodySphere, 2); bodySphere.ShapeBased = false; bodySphere.Mass = 1f; return sphere; } public JointBall createJoint( ObjectMeshDynamic object1, ObjectMeshDynamic object2, vec3 vec ){ return new JointBall(object1.Body, object2.Body, vec); } public void deleteJoint(Joint joint){ joint.Broken = true; joint.Enabled = false; } private void Init(){ Visualizer.Enabled = true; Unigine.Console.Onscreen = true; Physics.ShowShapes = Physics.SHOW_TYPE.SOLID; Physics.ShowJoints = true; Physics.ShowCollisionSurfaces = true; vec3 pos = new vec3(5,10,50); clone = createSphere(1f,pos,1); clone2 = createSphere(1f,new vec3(15,10,40),1); connectedJoint = createJoint(clone, clone2, pos); } float time; private void Update(){ time += Engine.IFps; if (time > 10f){ deleteJoint(connectedJoint); } } These 2 booleans are responsible of deleting the joint connection from the way I understood. Is there something extra that must be added or is this the correct approach? joint.Broken = true; joint.Enabled = false; Link to comment
bmyagkov Posted July 22 Share Posted July 22 Hello! This approach seems to be completely fine and the key trick was contained in the following lines: Quote new JointBall(object1.Body, object2.Body, vec); Thanks! 1 Link to comment
