christian.wolf2 Posted July 8 Posted July 8 Hi, I don't know if it is an bug or an common scenario now, but creating ObjectText in version 2.18.1 will apply the Unigine::text_base_error as default to the object. Simple code to reproduce: Spoiler Unigine::ObjectTextPtr text; AppWorldLogic::AppWorldLogic() {} AppWorldLogic::~AppWorldLogic() {} int AppWorldLogic::init() { // Create Object Text (created without a font or a text) text = Unigine::ObjectText::create(); // Defining a text to write and a font text->setText("Debug"); //applying the default material manually will avoid this and can be used as a workaround //Unigine::MaterialPtr mat = Unigine::Materials::findManualMaterial("Unigine::text_base"); //text->setMaterial(mat,0); text->setFontName("font.ttf"); text->setFontSize(100); text->setFontResolution(100); // Write here code to be called on world initialization: initialize resources for your world scene during the world start. return 1; } //////////////////////////////////////////////////////////////////////////////// // start of the main loop //////////////////////////////////////////////////////////////////////////////// int AppWorldLogic::update() { text->worldLookAt(Game::getPlayer()->getWorldPosition()); text->rotate(270,0,180); // Write here code to be called before updating each render frame: specify all graphics-related functions you want to be called every frame while your application executes. return 1; } //////////////////////////////////////////////////////////////////////////////// // end of the main loop //////////////////////////////////////////////////////////////////////////////// int AppWorldLogic::shutdown() { text->deleteLater(); // Write here code to be called on world shutdown: delete resources that were created during world script execution to avoid memory leaks. return 1; } Applying the default material manually to the ObjectText will fix this issue. Recompiling all shaders doesn't seem to help as well. We also didn't receive any error message. Best Christian
Solution silent Posted July 8 Solution Posted July 8 Hi Christian, That's known issue for 2.18.1, you need to manually set material for ObjectText after creation. I think this was fixed in the 2.19. Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
