hintuc_de Posted October 7, 2011 Share Posted October 7, 2011 На траве отображаются непонятные два прямоугольника, тени. Их положение меняется когда меняется положение камеры или солнца. Translate: On the grass appear incomprehensible to the two rectangles, shadows. Their positions changed when the camera or the sun positions had changed. Link to comment
manguste Posted October 7, 2011 Share Posted October 7, 2011 These are shadows from grass blades. Rectangles mark the end of your shadow casting distance (it is common for all objects in the world). So you can do one of the following: Disable shadow casting by the grass. Go to Nodes settings -> Surfaces tab and uncheck shadows options: Cast shadows and Cast world shadows boxes. You will also get performance boost in this case. Increase the shadow casting distance (which is BAD from performance point of view). Go to Render settings -> Comman tab and set Shadow distance to be further. You can also read the detailed info on how shadows from world light sources are rendered in the following article. Link to comment
hintuc_de Posted October 7, 2011 Author Share Posted October 7, 2011 Thnx, problem fixed. Shadows was disabled for grass. Link to comment
