[SOLVED] How to set diffuse color to material in C++ codes
Is there a way to set diffuse color in RGB color format to a material in C++ object ?
Something like below codes:
Material* a;
a->setParameter("diffuse",vec3(1.0f,0.5f,0.5f));
BTW , where I can check the full like of parameter in string type of material object ?
Thanks for any advice.
Edited by leon.dong
Hi Leon,
I propose to use Material::findParameter() to search for parameters in first place, which returns the parameter number in your material. For diffuse you need to look for "diffuse_color" (at least for any mesh_base.mat), which is an float4 variable. So Material::setParameterFloat4() is the best way to go, either with the parameter name or the parameter number.
Unfortunately there isn't any convenient documentation about this, but you can look in the .basemat file, while open them with a text editor. Usually you can find them at "<SDK_INSTALL_FOLDER>/data/core/materials/base/objects/mesh/mesh_base.basemat) for meshes. The other ones are in the dedicated material folder.
Hope that helps!
  • Thanks 1
1 hour ago, christian.wolf2 said:
Hi Leon,
Hope that helps!
Really helpful . Thanks.
Confirm one thing . The color in vec4 is RGBA or ARGB /?
Edited by leon.dong
Regarding your vector question, it is always RGBA. Please be aware that color parameters are always from 0 to 1, so maybe you need to divide the RGB color by 255.
The detail tab is used for detail textures. You can have a look here.
Best
Christian
Best
Christian
Thanks.
I tried below codes with no effect
		MaterialPtr myTempMat = baseMat->inherit(myTempMatName.c_str());
		int paraID=myTempMat->findParameter("diffuse_color");
		myTempMat->setParameter(paraID, Math::vec4(diffuse.x, diffuse.y, diffuse.z, 1.0));
Instead, if I call this , it has effect .
The problem is this code is for albedo . Since I only have diffuse and specular color info not albedo , How can I use it correcly?
myTempMat->setParameter(Unigine::Material::PARAMETER_COLOR, Math::vec4(diffuse.x, diffuse.y, diffuse.z, 255));
May I ask what engine version you are using? Because Material::setParameter() isn't defined for my version (2.18) and I can't even find the member function, started from 2.13+.
Also, what workflow is your baseMat using? You first need to change the state to specular workflow if already doing. You can also do this easily via code (Material::setState("workflow",1)).
love you , Christian .
Your answer is what I need. Material::setState("workflow",1) is very useful.
My engine version is very old . 2.7.1 .
so might be some API is different.
  • silent changed the title to [SOLVED] How to set diffuse color to material in C++ codes
