IzaZed Posted December 6, 2023 Share Posted December 6, 2023 Hi, I just wanted to ask if there's any way to achieve a lowpass effect for a specific SoundSource object. In my case I'd need it for underwater audio. I checked the API but I didn't find anything so far, and I'd like to avoid having to render out every audio file as regular and muffled. Link to comment
silent Posted December 6, 2023 Share Posted December 6, 2023 IzaZed Unfortunately, built-in SoundSource doesn't have any filters available. You can try to add SoundReverb zone and try to set it up to emulate underwater sound. Another potential solution is to use FMOD and control all the sounds / effects manually. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
IzaZed Posted December 6, 2023 Author Share Posted December 6, 2023 Thanks for the answer I'll have a look! Link to comment
IzaZed Posted December 6, 2023 Author Share Posted December 6, 2023 Are there any API examples for using FMOD? I looked around but all I could find is this here, which doesn't really tell me where I can find the examples Link to comment
silent Posted December 6, 2023 Share Posted December 6, 2023 You can find FMOD examples in SDK Browser in Samples -> 3rd Party -> Sounds. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
IzaZed Posted December 6, 2023 Author Share Posted December 6, 2023 This message appears when launching, although I did put the fmod.dll, fmodL.dll, fmodstudio.dll and fmodstudioL.dll into my Project/bin folder, I can't find a "UnigineFMOD_x64.dll" anywhere - I also enabled the FMOD plugin through the project configuration and also added the -extern_plugin "FMOD" Same thing happens with a new project. I double checked that I copied the x64 and not x86 files. In the sample (thanks for pointing me to it) I had the same message, only without the "UnigineFMOD_x64.dll", and that worked after I threw the dlls into the project Link to comment
silent Posted December 7, 2023 Share Posted December 7, 2023 Could you please specify which API are you using for your current project - C++ or C#? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
IzaZed Posted December 7, 2023 Author Share Posted December 7, 2023 Ah, sure, I'm actually using both in different projects, but the current one is C# Link to comment
silent Posted December 7, 2023 Share Posted December 7, 2023 In case of C# project you would need to re-configure existing project to add FMOD plugin. You can do it in SDK Browser: After that step you should be able to see UnigineFMOD_plugin_x64 dlls in <Project>/bin/plugins/Unigine/FMOD directory. In order to make this plugin load on engine startup you also need to add -extern_plugin UnigineFMOD to the command line arguments. If you are using VSCode to launch and debug application you can do it directly in <Project>/.vscode/launch.json file in Run Debug / Run Release sections ("args" key). Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
IzaZed Posted December 7, 2023 Author Share Posted December 7, 2023 working now, thanks so much! 1 Link to comment
