How to simulate aerial refueling
If you want to simulate the real refueling process in the air, how should the physical properties of the refueling tube be simulated?
Do you use a Rope Body or RagDoll Body?
You can experiment with both approaches and select that fit your needs best.
Another option is to use simply a MeshSkinned object with bones in order to get more precise controls on the hose animation.
  • 2 weeks later...
On 2023/12/4 at PM7点30分, silent said:
您可以尝试这两种方法并选择最适合您需求的方法。
另一种选择是仅使用带有骨骼的 MeshSkinned 对象,以便对软管动画进行更精确的控制。
Which method is more suitable?
How do you make a Rope Boby inelastic?
HI!
for your case you need to apply some parameters:
1. Increase number of iterations (10-20)
2. change Linear Stretch of BodyRope
I tried to reduce the value of LStretch, but the model would be too short.
No matter how I set it up, it looks like a rubber band.
try to add PhysicalForce to imitate wind behind airplane
and experiment with
