Openflight import via UI?
Is it possible to import Openflight .flt files through the user interface?
I have been able to read the contents of the files through script but not able to import the actual meshes.
Hi David,
I'm afraid there is no OpenFlight support in the latest UNIGINE Editor versions.
You can only implement your own FLT importer in runtime, but not in Editor using the Import System: https://developer.unigine.com/en/docs/2.17/code/usage/custom_import_plugin/index?rlang=cs
