Miguel-Alejandria Posted September 23, 2023 Posted September 23, 2023 (edited) Hi, good day. I'm trying to recreate a scene i did on unity some time ago, learning about materials and nodes but i have a little problem with the normal map. The normal maps looks too simple of like a downgrade with less details... here i show you: As you can see, unity's version has more details, also if i increase the the value to gain more details it looks like the normal affects the smoothness: I'm using a node from the art samples, because there is not a standard material created on the engine with the nodes and i don't have the technical knoledge to create it from zero... anyways, the material i'm using is called: parallax_stones_1 This is the texture and the import settings (custom because it has the g inverted. Tell me if you need the import settings from unity) Am i messing something here? Edit: i think the following images are better references: Edited September 23, 2023 by Miguel-Alejandria
silent Posted September 25, 2023 Posted September 25, 2023 Hi Miguel, Could you send us your current test project with your textures and materials? You can export it as upackage: https://developer.unigine.com/en/docs/2.17/editor2/managing_packages/#export_browser_assets Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Miguel-Alejandria Posted September 25, 2023 Author Posted September 25, 2023 (edited) Sadly i don't think i can because the 3d models and some textures and script are from unity's artists :( but i can send you the textures from the material i'm showing you because those textures are from textures.com, will a cube using that material be enough? Edit: i just cheked it is on github so i guess i wouldn't have any problem... so, where do you need me to send it? Edited September 25, 2023 by Miguel-Alejandria
silent Posted September 25, 2023 Posted September 25, 2023 You can attach upackage here or send me link via PM. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Miguel-Alejandria Posted September 25, 2023 Author Posted September 25, 2023 2 hours ago, silent said: You can attach upackage here or send me link via PM. sent
