More Property parameters
I am currently making use of the node import/export feature and applying a custom properties to my nodes. This seems to be a really powerful feature, but the lack of property parameter types such as vec3 mean I have to store 3 individual floats to store any custom vec3 data. Ideally I want my .prop files to be in the following format:
<properties version="1.00">
<property editable="1" name="fold">
 <parameter name="offset" type="vec3">0.0 0.0 0.0</parameter>
 <parameter name="axis" type="vec3">0.0 0.0 0.0</parameter>
 <parameter name="angle" type="float">0.0</parameter>
</property>
</properties>
I believe it would be of advantage to also include quat, vec4 and mat4 parameter types in a property too, even if they weren't intended to be editable through the editor as this may be more convenient for some.
you could cheat and use ParameterColor (which is a vec4)... for vec3,vec4 and quat classes.
If you access the data infrequently you can use a string.
But yes I would like this addition to the property system too :)
I think it's quite difficult to edit 16 components of matrix directly.
In Unigine script you can easily convert string to matrix and vice versa:
mat4(getParameterString(id))
setParameterString(string(mat4_identity));
