anurag Posted August 8, 2023 Posted August 8, 2023 (edited) I did the following STEPS exactly: but the asset imports as non-textured .where did I go wrong or miss a step or is this meant to happen. Edited August 8, 2023 by anurag
bmyagkov Posted August 8, 2023 Posted August 8, 2023 Hello! It seems that you have included only the ".mesh" asset which lacks any links to the materials used. As a result, the dependency tool simply ignores it during the packaging stage. To address this issue, consider packing your model along with the associated textures into a node reference (.node) asset. To do this, please follow these steps: Right-click on the model within the world hierarchy to open the menu. Select "Create a Node Reference" from the options. Once you've created the node reference, proceed to export it as a package. To do this: Open the asset browser and locate the created node reference. Right-click on the node reference. Select the appropriate export option from the menu, as demonstrated in the attached image. Thanks!
anurag Posted August 8, 2023 Author Posted August 8, 2023 Thank you for your very quick response @bmyagkov, Actually, I did esport all the materials and textures ( I also selected include dependencies) . They were just in a separate folder( If you see the last image you'll see MATERIALS folder) but it didn't work.However this statement is pointless because I tried your way and It worked. Thanks for that. Now lets say I have to make a package with dozens of models. I would need to select each object and create a node reference for all of them . Do I then need to export all of them separately as package or do I select the export option on the top taskbar like my earlier demo photo?
bmyagkov Posted August 8, 2023 Posted August 8, 2023 7 minutes ago, anurag said: Thank you for your very quick response @bmyagkov, Actually, I did esport all the materials and textures ( I also selected include dependencies) . They were just in a separate folder( If you see the last image you'll see MATERIALS folder) but it didn't work.However this statement is pointless because I tried your way and It worked. Thanks for that. Now lets say I have to make a package with dozens of models. I would need to select each object and create a node reference for all of them . Do I then need to export all of them separately as package or do I select the export option on the top taskbar like my earlier demo photo? Well, take a look at any of our free add-ons and you'll notice that each one always includes a ".node" asset for every presented model making it easier to use. I would recommend following this workflow: store each model in its dedicated ".node" asset and once everything else is ready simply pack it all together as you've described in your original message here. Thanks!
