Armikron Posted August 7, 2023 Share Posted August 7, 2023 (edited) Trying to pass uniform array of float2 to fragment shader in .basemat and having problems. I got advised to use CBUFFER in such case, but I have no idea where to put it and how to access it. I see example here: https://developer.unigine.com/ru/docs/latest/code/uusl/create_post?rlang=cpp But it's for shader, not material (also it's only in Russian version of documentation) BaseMaterial <parent=Unigine::mesh_unlit var_prefix=var texture_prefix=tex> { // options Option blend = [src_alpha one_minus_src_alpha] CBUFFER(parameters) UNIFORM float4 s_vertex_positions[50]; UNIFORM float2 s_vertex_texcoords[50]; END Group "Base" { Color color = [1 1 1 1] Slider opacity = 1.0f Texture2D text = "ui/sdf_text.png" <unit=0 auto_init=true> } Shader vertex_struct = #{ INIT_BASE_DATA #} Shader common = #{ #} Shader vertex = #{ #} Shader fragment = #{ float a = var_s_vertex_texcoords[0].x; float4 col = float4(a, 1.0, 1.0, 1.0); OUT_FRAG_COLOR = col.rgb; OUT_FRAG_OPACITY = var_opacity; #} } This gives me 'undeclared' error. Edited August 7, 2023 by Armikron Link to comment
sweetluna Posted August 8, 2023 Share Posted August 8, 2023 Hi, CBUFFER is UUSL's declaration of Constant Buffer as seen in - UUSL Keywords and Types - Documentation - Unigine Developer. There for you should move it into Shader common. Shader common = #{ CBUFFER(parameters) UNIFORM float4 s_vertex_positions[50]; UNIFORM float2 s_vertex_texcoords[50]; END #} And since they are not autogenerated by the material but rather declared implicitly in the shader it self - neither of uniforms will have var_ prefix. In other words you should replace this line float a = var_s_vertex_texcoords[0].x; With float a = s_vertex_texcoords[0].x; In C++/C# code you have to get specific Render Passe's Shader object and assign array values to it. Instead, what you can do is - specify arrays as material parameters at the material heading: Group "Base" { Color color = [1 1 1 1] Slider opacity = 1.0f Texture2D text = "core/textures/common/checker_d.texture" <unit=0 auto_init=true> } ArrayFloat4 vertex_positions <size=50> ArrayFloat2 vertex_texcoords <size=50> // ... In shader you should use this: float a = var_vertex_texcoords[0].x; Notice absence of s_ prefix and presence of var_ one. That is due to the fact that we declared vertex_positions as a material parameter. All material parameters will have var_ prefix. From C++/C# stand point now you should use setParameterArray for setting values up. Hope this helps! 1 May RenderDoc/Nsight Graphics/Intel GPA bless you Link to comment
Armikron Posted August 8, 2023 Author Share Posted August 8, 2023 Thanks, 2nd method is more straightforward. Link to comment
