[WidgetSpriteNode]I can't remove node from world.
Posted
i try to use WidgetSpriteNode class.
i want to draw a node in WidgetSpriteNode.
but the node appear at WidgetSpriteNode with worldscene.
i wrote this script.
// my script
m_lbSpriteNode = new WidgetSpriteNode(gui, 430, 600);
Node node = node_load("mesh.node");
m_lbSpriteNode.setProjection(ortho(-10, 10, 50, -1, 0.1f, 100.0f));
m_lbSpriteNode.setModelview(lookAt(vec3(0,-1,0), vec3(0,1,0), vec3(0,0,1)));
m_lbSpriteNode.setNode(node);
// Transparent background viewport
m_lbSpriteNode.setBlendFunc(GUI_BLEND_SRC_ALPHA,GUI_BLEND_ONE_MINUS_SRC_ALPHA);
engine.render.setAmbientColor(vec4(1, 1, 1, 1));
// remove
engine.editor.removeNode(node);
or
node_remove(node);
but i was failed remove from worldscene.
can i remove the node from worldscene for only use in WidgetSpriteNode ?
Posted
You shouldn't pass each node into the engine.editor to render it. All existed and enabled nodes are rendered. You can select nodes for WidgetSpriteNode by using viewport mask.
Posted
thanks, frustum :(
i can change viewportmask. (T -> Camera -> viewportmask, or unigine_editor.cfg -> tools_camera_viewport_mask).
i have more question.
How can i change in script? i can't find any script function.
Posted
thanks ulf.schroeter, :(
i read bitmasking overview, too
i want to change worldscene ViewportMask in script.(T key -> Camera -> Viewportmask)
usually, this function(object.setViewportMask(), WidgetSpriteNode.setViewportMask()) used to hide the node in WidgetSpriteNode.
and if worldscene viewportmask is -1(0xffffffff), this function(object.setViewportMask(), WidgetSpriteNode.setViewportMask()) lose meaning.
Posted
Set object viewport mask of all world objects to x00000001 and only for the object(s) you want to render in WidgetSpriteNode set their viewport mask to 0x00000003. You will select only these objects for sprite rendering via setting WidgetSpriteNode viewportmask to 0x00000002.
