nitrooo Posted July 12, 2023 Share Posted July 12, 2023 I have just tested Superposition demo and some C++ API samples and they do not work in fullscreen mode. There are some errors: WindowManager::WindowManager(): SetProcessDpiAwareness bad result SystemProxySDL::enableWindowFullscreen(): Can't enable fullscreen mode (display:0 mode:-1) Log attached. log.txt Link to comment
silent Posted July 12, 2023 Share Posted July 12, 2023 nitrooo Thanks for the bug report. We will try to reproduce this on our end. However, we need to understand your current monitors setup. Could you please send us the dxdiag information so that we can try to replicate the same environment as yours? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
nitrooo Posted July 12, 2023 Author Share Posted July 12, 2023 Sure, please find it attached. DxDiag.txt 1 Link to comment
silent Posted July 13, 2023 Share Posted July 13, 2023 Thank you! So far we have only a single way of reproducing this behavior (by adjusting process DPI Awareness level). As I understand correctly, the steps required for this to appear are following: Download UNIGINE SDK 2.17.x Download Superposition (or any other demo) In SDK Browser -> Global Options adjust API to Vulkan, enable fullscreen option, adjust resolution to current desktop resolution (in your case 3840x2160) Click Apply to confirm the setting Launch Superposition (or any other demo) from SDK Browser by clicking Run button Is that correct? Or you actually did something different? The only case when we observe non-working fullscreen mode and errors in log is when we manually adjust Compatibility settings for the downloaded .exe in it's properties: Any option enabled in High DPI scaling override section will lead to non-working fullscreen mode. By default DPI scaling enabled automatically on engine start-up and there is no need to tweak any of these scaling options - Override high DPI scaling checkbox should be disabled. You can also check with Process Explorer current process DPI Awareness level. Using Process Explorer, Select the View file option menu, and in the drop down menu, select Select Columns… In the window that opens, select DPI Awareness. If you see Unaware it means that something is overriding default engine behavior (either by modifying compatibility option, or by using external manifest files, or any additional way...): Per-Monitor Aware should be the correct value in this tab. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
nitrooo Posted July 13, 2023 Author Share Posted July 13, 2023 Steps are correct, but desktop settings should be 3840x2160 150% DPI. With that configuration Unigine can't enter fullscreen mode or displays only part of the image depending on SDK Browser Global Options. Attached images show configurations. When desktop is set to native 3840x2160 100% DPI, unigine enters fullscreen mode correctly, but obviously fonts are too small. You have serious issues with DPI scaling so far. It looks that you either can't enter fullscreen, because there is no such videomode as 4K*150%, or trying to scale the window (or its content) by 150% what results in part of the viewport being cut out. Link to comment
silent Posted July 14, 2023 Share Posted July 14, 2023 Thanks for providing the additional information. However, at this moment, we were not able to reproduce this behavior, even on our 4K monitors. We will continue our attempts to reproduce this next week :) How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
nitrooo Posted July 14, 2023 Author Share Posted July 14, 2023 Maybe it depends on Windows version... Anyway I managed to enter fullscreen mode correctly with the following code. It means that API works correctly and you are doing something else wrong. I noticed that Displays::getDesktopMode() returns -1 at the beginnig and maybe that is why there is this log: "SystemProxySDL::enableWindowFullscreen(): Can't enable fullscreen mode (display:0 mode:-1)". Just guessing... int current_display = Displays::getCurrent(); int desktopMode = Displays::getDesktopMode(current_display); Log::message("current desktop mode %d\n", desktopMode); Math::ivec2 desktopResolution; Math::ivec2 resolution; int desktopRate; int rate; desktopResolution = Displays::getResolution(current_display); desktopRate = Displays::getRefreshRate(current_display); Log::message("current resolution %d %d\n", desktopResolution.x, desktopResolution.y); Log::message("current rate %d\n", desktopRate); int numModes = Displays::getNumModes(current_display); int selectedMode = -1; for (int i = 0; i < numModes; i++) { resolution = Displays::getModeResolution(current_display, i); rate = Displays::getModeRefreshRate(current_display, i); Log::message("supported resolution %d %d %d %d\n", i, resolution.x, resolution.y, rate); if (resolution.x == desktopResolution.x && resolution.y == desktopResolution.y && rate == desktopRate) { selectedMode = i; } } EngineWindowViewportPtr main_window = WindowManager::getMainWindow(); if (main_window) { if (selectedMode >= 0) { bool ok = main_window->enableFullscreen(current_display, selectedMode); if (ok) { Log::message("fullscreen set, mode=%d\n", selectedMode); } } } 1 Link to comment
