Amerio.Stephane Posted June 30, 2023 Share Posted June 30, 2023 Hi, I'm spawning node in geo terrain (curved and flat), and I just want to make sure I'm doing it correctly. auto converter = ig->getConverter(); Mat4 transform = converter->getZeroBasis(geo); node->setWorldTransform(transform); vec3 up = converter->getZeroUpDirection(geo); quat q = converter->getZeroRotation(geo); node->setWorldRotation(quat(up, yaw) * q); // rotate the yaw of the node. 0 should be face north, 90 should be face east. Not sure here! Can you confirm this is the correct way, that I'm not messing up the quat order? Thanks! Link to comment
cash-metall Posted June 30, 2023 Share Posted June 30, 2023 Hello! Yes, you are on the right way, but you got a little lost with the order of applying rotations // input Vec3 geo = Vec3(lat,lon,alt); vec3 euler_ned = vec3(yaw, pitch, roll); vec3 euler_enu = vec3(roll, pitch, yaw); // there are can be different sign. im not shure about direction of rotation CW or CCW // === usual way with flat vec3 world_pos = geodeticToWorld(geo); quat world_rot = quat(composeRotationZYX(euler_enu)); // OR if you have a ned rotation quat world_rot = quat(0.0f, 0.0f, -1.0f, euler_ned.z) * quat(1.0f, 0.0f, 0.0f, euler_ned.y) * quat(0.0f, 1.0f, 0.0f, euler_ned.x); Mat4 final_transform = Mat4(world_rot, world_pos); // ==== with geodetic curved vec3 world_pos = geodeticToWorld(geo); quat world_rot = quat(composeRotationZYX(euler_enu)); quat zero_basis = getZeroRotation(geo); // rotation of local tanget plane for this point Mat4 transform = Mat4(zero_basis * world_rot, world_pos); // compose rotation of ltp with rotation of entity // or just Mat4 transform = getZeroBasis(geo) * Mat4(world_rot.getMat3()); // im not shure about altitude in this case but it should works to... 1 Link to comment
