Amerio.Stephane Posted June 26, 2023 Share Posted June 26, 2023 Hi, In 2.17 the plugin naming convention has changed. It's not clear if the function virtual const char * get_name() override { return "MyPluginName"; } should now reflect the real plugin name <VendorName><PluginName> or if the string is totally free. Is the returned string used in any way by the engine (apart from logging the loaded plugins name)? Thanks! Link to comment
cash-metall Posted June 27, 2023 Share Posted June 27, 2023 Hello! 16 hours ago, Amerio.Stephane said: Is the returned string used in any way by the engine (apart from logging the loaded plugins name)? this string is only used to identify the plugin (findPlugin, destroyPlugin, getPluginName) note: when you call addPlugin("MyPlugin") , it will search by filename, but stored by get_name (because there can be several plugins in one dll). So we recommend keeping get_name and file name the same. 1 1 Link to comment
