[SOLVED] How to receive message from UDP server?
I'm learning the socket from the document, I made an UDP client, the send function is working well, but the receive function does't work. My UDP server is a third tool, so it can't be the server's problem. Please point out my mistakes, thanks! And this is my code.
Hello!
can you tell in more detail what is happening - the application freezes? or the socket cannot read anything? or reads, but there is not the information that you expected?
is `reciveupdate` method called every frame?
you can try to add some checking and extralogs to understand what is going on
if (socket->isOpened())
	if (socket->isReadyToRead(1000 /*1 ms*/))
		Log::message("ready to read!\n");
		int size = socket->readStream(blob, RECV_SIZE);
		if (size>0)
			Log::message("read %d bytes!\n", size);
		// dosmth
		else
			Log::warning("read nothing :(\n");
	else
		Log::message("z");
else
	Log::error("socket closed!\n");
5 hours ago, cash-metall said:
Hello!
		if (size>0)
		// dosmth
		else
	else
		Log::message("z");
else
Thanks for your reply!
The detail is the application can't read any message, and "receiveupdate" method called every frame, I also make the application run in background, so the application doesn't freeze, but it can't work.
Sorry for my poor English expression,it's not "make", it's "I set the application can run in background".
have you tried adding the logs I mentioned above? can you show the output of the application?
Your code looks correct. How can i reproduce this behavior? what kind of 3rd party server: is this something private or can i download it?
I tried add that, and here is the log:1591699089_QQ20230628150757.thumb.png.9344d1379358bd764cb4d417f3eb974c.png
this is my UDP server tool:1853616724_QQ20230628150500.png.b13067ffde17587d955145c44c85c142.pngNetAssist.exe
I tried to use "socket->block();", when I click send button in the 3re party server, the unigine application appended a "z" character, so I think my application can receive the message, but it can't read the message.
here is the video
2023-06-28_15-33-44.mkv
thanks for the help with replay!
i found the problem: you don't need to use  socket->bind when creating a socket.
this is my version
SocketPtr socket;
#define SOCKET_BUFFER_SIZE 256
#define MAX_READ_UDP_SIZE 65535 // maximum possible UDP packet (IPv4, not Jumbo)
#define MAX_SEND_UDP_SIZE 1432	// default MTU, excluded IP and UDP headers
void encodePacket(const BlobPtr &blob)
	String s = "Helloworld!!!";
	blob->write(s.get(), s.size());
	Log::message("\n------- send %s -------\n", s.get());
void decodePacket(const BlobPtr &blob)
	Log::message("\n==== new message ====\n");
	const char *s = (const char *)blob->getData();
	Log::message("%s", s);
	Log::message("\n==== end message ====\n");
int AppSystemLogic::init()
	Engine::get()->setBackgroundUpdate(true);
	socket = Socket::create(Socket::SOCKET_DGRAM);
	if (!socket->open("127.0.0.1", 7777) ||
		!socket->recv(SOCKET_BUFFER_SIZE) ||
		!socket->send(SOCKET_BUFFER_SIZE) ||
		!socket->nonblock())
		Log::error("can't create send UDP socket\n");
int AppSystemLogic::update()
	if (Input::isKeyDown(Input::KEY_S))
		BlobPtr packet = Blob::create();
		encodePacket(packet);
		if (packet->getSize() > MAX_SEND_UDP_SIZE)
			Log::warning("size more then MTU. blob can be segmented!\n");
		if (packet->getSize() > MAX_READ_UDP_SIZE)
			Log::error("size more then MAX UPD for IPv4\n");
		socket->write(packet->getData(), packet->getSize());
	if (socket->isReadyToRead(100000 /*100 ms*/))
		int src_size = (int)socket->readStream(packet, MAX_READ_UDP_SIZE);
		if (src_size)
			packet->seekSet(0);
			decodePacket(packet);
	// Write here code to be called before updating each render frame.
this is my version
SocketPtr socket;
		if (src_size)
			packet->seekSet(0);
it works! Thank you very very much!
You're welcome!
  • bmyagkov changed the title to [SOLVED] How to receive message from UDP server?
