[SOLVED] A problem about c++'s pointer array
How to declare an array of pointer? I am a beginner in cpp programing, I try to declare a pointer array like c#'s grammar, but it doesn't work. Please tell me how to do that and how to create a variable array, thanks!
Hi, lgdnpt!
You can do it like this:
Unigine::Vector<Unigine::JointWheelPtr> jointWheels;
You can find more information about Unigine::Vector API in the documentation, and since Unigine::Vector works similar to std::vector and you are beginner in C++, I would recommend you to learn more about C++ STL (Standard Template Library) Containers and Iterators. I'm sure It will be really useful to you!
3 hours ago, moody_pooch said:
Hi, lgdnpt!
  • silent changed the title to [SOLVED] A problem about c++'s pointer array
Hi, lgdnpt!
Oh, I found my other mistake, I didn't use namespace when I declare the JointWheelPtr, thanks again, very, very thank you!
