[SOLVED] ComponentVariableArray
Let's say I have this in my .prop file:
<parameter name="blah" type="array" array_type="int" array_dim="0"/>
And this in my .H file:
PROP_ARRAY(Int, blah)
This does not work on the CPP side:
	for (int i = 0; i < blah.size(); ++i)
		int someInt = blah[i];
I can actually see the definitions inside <UnigineComponentSystem.h>.
What am I missing?
Quote
Tell us in more detail what exactly does not work and how do you check?
everything looks right, it should work.
my code:
// in test.h
class TEST: public Unigine::ComponentBase
	COMPONENT_DEFINE(TEST, Unigine::ComponentBase);
	COMPONENT_INIT(init);
	PROP_ARRAY(Int, blah);
	void init();
// in test.cpp
#include "test.h"
REGISTER_COMPONENT(TEST);
void TEST::init()
	Log::message("BEGIN\nsize of blah array on %s(%d) node is %d\n", node->getName(), node->getID(), blah.size());
		Log::message("parameter %d = %d\n", i, someInt);
	Log::message("END\n");
setting in editor
console output:
BEGIN
size of blah array on sun(824505625) node is 4
parameter 0 = 6
parameter 1 = 5
parameter 2 = 4
parameter 3 = 3
END
show a screenshot of how exactly you filled the array, and your console output
Sorry to bother. This was caused by the fact that the function was defined as const :) Removed it and it's working.
  • silent changed the title to [SOLVED] ComponentVariableArray
