Amerio.Stephane Posted March 16 Share Posted March 16 Hi, we use this code to trigger a callback when the meteo is changed through CIGI: if (auto ig = IG::Manager::get()) { cbOnMeteoChanged = ig->getMeteo()->addOnMeteoChangedCallback(MakeCallback(this, &MyComponent::on_meteo_changed)); on_meteo_changed(); } But once triggered, the callback is always called, on every frame, even if the CIGI host stop sending data. Link to comment
bmyagkov Posted March 17 Share Posted March 17 Hello! @Amerio.Stephane We are pleased to inform you that we have successfully reproduced the issue and have already implemented a fix in our internal version. However, we regret to inform you that there is currently no workaround available to avoid this behavior. We would appreciate it if you could clarify the severity of the problem for you at present. Would you prefer to wait for the next SDK update or do you require a patch to be issued? Thanks! Link to comment
Amerio.Stephane Posted March 17 Author Share Posted March 17 This is not critical at the moment, as the callback does really little work; but in the future this could become an issue. So no need for a hotfix at the moment, thanks. 1 Link to comment
