Can't remove Input::CALLBACK_IMMEDIATE_INPUT callbacks
We have some Input::CALLBACK_IMMEDIATE_INPUT callbacks.
But the remove/clear callbacks functions don't remove the added callbacks
on_immediate_input_callback = MakeCallback(this, &InteractiveWorldLogic::on_immediate_input);
Input::addCallback(Input::CALLBACK_IMMEDIATE_INPUT, on_immediate_input_callback);
// now try to remove it
Input::removeCallback(Input::CALLBACK_IMMEDIATE_INPUT, on_immediate_input_callback);
// it's still there
Input::clearCallbacks(Input::CALLBACK_IMMEDIATE_INPUT);
// nope, still there also!
This is problematic because at shutdown, the callback is still called when we enter "quit" in the console, and the code crash...
int MyWorldLogic::shutdown()
    // doesn't work, the callback is still called if I type "quit" in the console
void MyWorldLogic::on_immediate_input(InputEventPtr e)
	if (Console::isActive()) //<--crash, because engine is already destroyed
		return;
Are we mis-using the API?
To remove callbacks you need to use the identifier that is returned when adding.
	void on_immediate_input(InputEventPtr e);
	void *callback_id{nullptr};
int AppWorldLogic::init()
	callback_id = Input::addCallback(Input::CALLBACK_IMMEDIATE_INPUT, MakeCallback(this, &AppWorldLogic::on_immediate_input));
int AppWorldLogic::shutdown()
	Input::removeCallback(Input::CALLBACK_IMMEDIATE_INPUT, callback_id);
Also currently the Input::clearCallbacks() method has an empty implementation, because internally the engine now uses the same callbacks. This will be fixed in the future with an updated event system.
Classic me reading doc too fast. I could have sweared the returned pointer was the callback itself.
Thanks, I'll fix our code!
