Amerio.Stephane Posted March 8 Share Posted March 8 Hi, At runtime, we are creating and then attaching some node to an entity inner child. For example, we have an entity with a dummy placed at some key points inside (think of it as a socket node), and we create a node (could be a camera, could be a mesh) and then attach it to the entity during run time. We keep a NodePtr to the added node and use it to move/rotate it. All work great until we reload the database or we receive a CIGI packet that changes the entity type, and this of course deletes the socket dummy node in the entity node. And it apparently also deletes the node we attached to it, hence our stored NodePtr points to nothing and we crash. Is there a way to "catch" the entity type chane event so we can handle this case more nicely Is there any other way to attach a node to the entity with code at run-time. I though about using a child entity, but this can leads to other issues (the child id may be needed by the sim, we can't reserve it, and we need to dynamically change the content, its not a fixed set) Thanks! Link to comment
cash-metall Posted March 10 Share Posted March 10 Hello! On 3/8/2023 at 9:01 PM, Amerio.Stephane said: Is there a way to "catch" the entity type chane event so we can handle this case more nicely no, there is no callback for changing the entity type. we will add in 2.17 two new callbacks (they are already implemented) - Entity::addOnBeforeChangeTypeCallback - Entity::addOnChangedTypeCallback On 3/8/2023 at 9:01 PM, Amerio.Stephane said: Is there any other way to attach a node to the entity with code at run-time. I though about using a child entity, but this can leads to other issues (the child id may be needed by the sim, we can't reserve it, and we need to dynamically change the content, its not a fixed set) You сan attach the node not to the model itself, but to the root node. some_part_node->getRootNode(); // or entity->getNode(); this node is not deleted or changed when the type is changed. Link to comment
Amerio.Stephane Posted March 10 Author Share Posted March 10 4 hours ago, cash-metall said: You сan attach the node not to the model itself, but to the root node. this node is not deleted or changed when the type is changed. Ooh this is a nice thing to know! Thanks. In the mean time, I found a way to be alerted when an object has been destroyed. I created a "ShutdownComponent" whose only role is to call a callback when it is itself destroyed (in its shutdown method). By adding this component to our additional node, at least we can be alerted when it has been destroyed and do some cleanup or recreate it. Link to comment
