Highlighting an object ... but without the Visualizer?
I'd like to be able to highlight a specific object at runtime, by adding some kind of transparent overlay over it for a short duration. The object may be any StaticMesh, but it's existing material must remain untouched.
The Visualizer::renderSolidObject() would fit my need, but as it's a Visualizer call, it requires that the Visualizer is enabled. But enabling it would also render visible a lot of debug traces we don't want the customer to see.
What would be an easy solution?
Alas I know about this one, but the issue here is I must not modify the material in any way. To be more explicit, the material may already use Auxiliary for other purposes, or it may be a material graph that doesn't expose the auxiliary channel.
So the only way I could think off is to redraw the meshes with an alternate material, but how can I do that?
Quote
You could switch to a clone of the object with a different material. Then Unigine would handle rendering.
How could I do that, without preparing in advance the cloned object. Everything must be done at runtime.
Quote
Nothing hinders you to call clone on a node during runtime. Of course it would not be optimal for large amount of nodes but if its only one node at a time like in your case it should not be a problem.
Hi Stephane,
You can render objects into a separate texture that you could use as a mask. Notice that you actually want to render only the depth of selected objects.
Then just apply custom post effect / scriptable material that will use this mask to determine where to draw an outline.
  • 8 months later...
(исправил текст первого абзаца , который почему-то автозаменился, как будто перевелся на англ, а потом обратно на русский)
Извините, а можно новичку продолжить тему?
Мне также пришлось столкнуться с подобным, и я стал искать решение.
Заливка поверхности декалью, или маской в том или ином виде есть и всё отлично, но вопрос остался с контуром. Изучая семплы я посмотрел и пост-эффект с выделением и эффект собеля, а также подсветку с "auxiliary".
Смотрел и
Варианты не дают удовлетворительного результата.
Вспомогательный материал просто создал дочерний материал от базового, доп заливку с помощью декали. Всё выглядит отлично, кроме контура. Мало того, что я не могу сделать обводку чёрным цветом, так ещё, я не знаю от чего, если перемещать камеру, появляется засветка по краям экрана (например, на экране - сверху). image.thumb.png.4443a826a9af0d267c12e63c0ea94e02.png
Далее стал пробовать взять шейдер с пост-эффектом. Заливка есть, немного уже другая, но рамка не рисуется вокруг объекта. Только небольшой квадрат (размеры текстуры Маска Альбедо), слева внизу на фоне самого объекта, к которому применяется данный материал.
Сразу оговариваюсь, что постэффекты мне не подходят, так как они применяются ко всем объектам, и мне необходимо применить определенное выделение/заливку, только к объектам, выбранным в рантайме. Ну и вот не понимаю, как с этим бороться - если в кадре нет ни одного объекта, к которому применяется шейдер постобработки, получается вот что:image.thumb.png.48286a78cbdb11a4837b5795b09b18c4.png
Теперь пытаюсь разобраться в семпловом графе пост-эффекта, ту часть, где цикл, ведь рисует он небольшой прямоугольник слева-внизу экрана.
Вопрос у меня вот какой план. Постэффекты ведь рисуются уже после подготовки кадра, а во время подготовки кадра, можно ли как-то в графе правильно представить обводку видимой части объекта по координатам, по контуру?
Или такие манипуляции необходимо провести уже после подготовки базового изображения, и то, что я хочу нереализуемо?
Спасибо.
Edited by Ry_Mik
Внезапный автоперевод с русского на англ и обратно
