Amerio.Stephane Posted January 18 Share Posted January 18 (edited) Hello, I have a ComponentStruct embedded in a Component defined like this class MyComponent : public Unigine::Plugins::IG::NetworkComponentBase { public: COMPONENT(MyComponent, Unigine::Plugins::IG::NetworkComponentBase); COMPONENT_INIT(init); COMPONENT_SHUTDOWN(shutdown); void init(); void shutdown(); PROP_NAME("MyComponent"); struct MyType : public Unigine::ComponentStruct { PROP_PARAM(String, label, "", "Label"); }; PROP_ARRAY_STRUCT(MyType, mytypes); }; And it is dynamically added at runtime with this code: int prop_index = nodeMrf->addProperty("MyComponent"); auto prop_param = nodeMrf->getProperty(prop_index)->getParameterPtr(); prop_param->getChild("mytypes")->setArraySize(2); for (int i = 0; i < 2; ++i) { auto p = prop_param->getChild("mytypes")->getChild(i); p->getChild("label")->setValueString("ok"); } This works great... until I try to retrieve the "label" values. for (int i = 0; i < v->mytypes.size(); ++i) { // v is a MyComponent* MyComponent::MyType const& t = v->mytypes[i]; Log::message("1> %s\n", t.label.getValueAsString().get()); Log::message("2> %s\n", t.label.get()); Log::message("3> %s\n", t.label.getValueAsString().get()); } This outputs: 1> 2> ok 3> ok 1> 2> ok 3> ok getValueAsString() returns nothing, unless I first call get(). What is going on? Am I miss-using the API? Edited January 18 by Amerio.Stephane Link to comment
cash-metall Posted January 19 Share Posted January 19 PropertyParameterString::getValueAsString does not update the value, this method is needed for intern serialization. I don’t know why it is placed in public methods, it probably needs to be hidden. To work you can use the conversion operator //PROPP_PARAM(String, str_param) //PROPP_PARAM(Int, int_param) String strvalue = str_param; int ivalue = int_param; or the get() method in cases where the compiler cannot call this operator properly, for example: Log::message("print: %d %s\n", ivalue.get(), strvalue.get()); also you can add new component like this: MyComponent * c = ComponentSystem::get()->addComponent<MyComponent>(nodeMrf); c->mytypes.resize(2); for (int i = 0; i < 2; i++) c->mytypes[i]->label = "ok"; 1 Link to comment
Amerio.Stephane Posted January 19 Author Share Posted January 19 Okay, I'll remove all usage of getValueAsString(). Better to mark it private, indeed. Thanks for the cleaner way to add the Component too :) Link to comment
