KOVIAHN Posted December 23, 2022 Share Posted December 23, 2022 hello. I am trying to create an ObjectMeshSkinned that moves or rotates the object's mesh. The purpose is to create an object of that shape and then export it as an animated fbx. I am trying to use keyframes. I want to simply move it to the position of -1 at frame 0 and 1 at frame 1. int AppWorldLogic::init() { // load a mesh from the file MeshPtr mesh = Mesh::create("core/meshes/box.mesh"); // create a new boundbox for the mesh including new surface mesh->createBounds(); //Appends an animation int animation = mesh->addAnimation(); //Sets the number of animation frames mesh->setNumAnimationFrames(0, 2); Vector< Math::vec3 > xyz; Vector< Math::quat > rot; Vector< Math::vec3 > scale; xyz.push_back(Math::vec3(-1.0f)); xyz.push_back(Math::vec3(1.0f)); //Updates the animation frame mesh->setAnimationFrame(0, 0, xyz, rot, scale); Vector< Math::vec3 > rxyz; Vector< Math::quat > rrot; Vector< Math::vec3 > rscale; //check animation frame. mesh->getAnimationFrame(0, 0, rxyz, rrot, rscale); //make new skin mesh staticMesh = ObjectMeshSkinned::create(mesh); //create layer? staticMesh->setLayer(0, true, 0.0f); //set animation staticMesh->setAnimation(0, 0); staticMesh->setLoop(true); // Write here code to be called on world initialization: initialize resources for your world scene during the world start. return 1; } Unigine::ObjectMeshSkinnedPtr staticMesh; //////////////////////////////////////////////////////////////////////////////// // start of the main loop //////////////////////////////////////////////////////////////////////////////// int AppWorldLogic::update() { int nNumFrame = staticMesh->getNumFrames(0); staticMesh->setFrame(0, 0); ///staticMesh->setFrame(1, Unigine::Game::getTime() * 25.0f); // Write here code to be called before updating each render frame: specify all graphics-related functions you want to be called every frame while your application executes. return 1; } However, something is wrong and the animation doesn't work. Please tell me which part should be added. Lastly, this year is just around the corner, and we are very grateful for your support and help. I wish you a good end of the year and Christmas. Link to comment
alexander Posted December 26, 2022 Share Posted December 26, 2022 Hi KOVIAHN, Quote I am trying to create an ObjectMeshSkinned that moves or rotates the object's mesh. Unfortunately, ObjectMeshSkinned only supports bone-based animation now. Mesh animation is not supported. Mesh::setAnimationFrame() method is linked to the method Mesh::setAnimationBones(). For example: Vector<short> bones; Vector<Math::mat4> frames; bones.resize(10); frames.resize(10); mesh->setAnimationBones(0, bones); mesh->setNumAnimationFrames(0, 2); int frame_index = 0; // first frame frames[0] = ...; // sets first bone position/rotation/scale for the first frame frames[1] = ...; // sets second bone pos/rot/scale for the first frame mesh->setAnimationFrame(0, frame_index, frames); frame_index = 1; // second frame frames[0] = ...; // sets first bone position/rotation/scale for the second frame frames[1] = ...; // sets second bone pos/rot/scale for the second frame mesh->setAnimationFrame(0, frame_index, frames); The only way to move the object's mesh is the Tracker tool. Or, you can create your own simple animation system. Best regards, Alexander Link to comment
KOVIAHN Posted December 26, 2022 Author Share Posted December 26, 2022 Hi alexander Thank you for your answer. I noticed that ObjectMeshSkinned is animated in bone based animation. I also understood implementing a tracker tool and a simple animation system. But I still have a question. https://developer.unigine.com/en/docs/2.16.1/api/library/rendering/class.mesh?rlang=cpp#addBone_cstr_int_int Is it possible to animate after adding a bone to a cube-like mesh where no bone exists through the AddBone function? I called the function to test the animation, but there is still no response, so I ask. Link to comment
alexander Posted December 26, 2022 Share Posted December 26, 2022 Quote Is it possible to animate after adding a bone to a cube-like mesh where no bone exists through the AddBone function? Yeah, you can do that. But, after adding Mesh::addBone() you need to call these 3 methods for every vertex of your mesh also: Mesh::setWeightCount(vertex_num, 1, 0); Mesh::setWeightWeights(vertex_num, ivec4(1), 0); Mesh::setWeightBones(vertex_num, ivec4(0), 0); Best regards, Alexander Link to comment
KOVIAHN Posted January 2, 2023 Author Share Posted January 2, 2023 Dear alexander :) I wish you a happy new year and a good holiday season. I tried coding after reading the article you wrote above, but it still doesn't work. int AppWorldLogic::init() { // load a mesh from the file MeshPtr mesh = Mesh::create("core/meshes/plane.mesh"); // create a new boundbox for the mesh including new surface mesh->createBounds(); int nCount = mesh->getNumVertex(0); mesh->setNumWeights(4, 0); mesh->setWeightCount(0 ,1, 0); ////Appends an animation int animation = mesh->addAnimation(); int nBone1 = mesh->addBone(); int nBone2 = mesh->addBone(); mesh->setBoneTransform(0, (mat4)Math::translate(-0.25,0,0)); mesh->setBoneTransform(1, (mat4)Math::translate(0.25,0,0)); //mesh->setNumWeights() int VertextCount = mesh->getNumVertex(0); Unigine::Math::vec3 v1 = mesh->getVertex(0, 0); //-0.5, -0.5. 0 Unigine::Math::vec3 v2 = mesh->getVertex(1, 0); //-0.5, 0.5. 0 Unigine::Math::vec3 v3 = mesh->getVertex(2, 0); //0.5, -0.5. 0 Unigine::Math::vec3 v4 = mesh->getVertex(3, 0); //0.5, 0.5. 0 int nBones = mesh->getNumBones(); mesh->setWeightCount(0, 1, 0); mesh->setWeightWeights(0, vec4(1.0,0.0, 0, 0), 0); mesh->setWeightBones(0, ivec4(0, 0, 0, 0), 0); mesh->setWeightWeights(0, Unigine::Math::vec4(1.0f, 0.0, 0.0, 0.0), 0); mesh->setWeightCount(1, 1, 0); mesh->setWeightWeights(1, vec4(1.0, 0.0, 0, 0), 0); mesh->setWeightBones(1, ivec4(0, 0, 0, 0), 0); mesh->setWeightWeights(1, Unigine::Math::vec4(1.0f, 0.0, 0.0, 0.0), 0); mesh->setWeightCount(2, 1, 0); mesh->setWeightWeights(2, vec4(1.0, 0.0, 0, 0), 0); mesh->setWeightBones(2, ivec4(1, 0, 0, 0), 0); mesh->setWeightWeights(2, Unigine::Math::vec4(1.0f, 0.0, 0.0, 0.0), 0); mesh->setWeightCount(3, 1, 0); mesh->setWeightWeights(3, vec4(1.0, 0.0, 0, 0), 0); mesh->setWeightBones(3, ivec4(1, 0, 0, 0), 0); mesh->setWeightWeights(3, Unigine::Math::vec4(1.0f, 0.0, 0.0, 0.0), 0); Vector<Math::mat4> frames; frames.resize(2); mesh->setNumAnimationFrames(0, 2); int frame_index = 0; // first frame frames[0] = (mat4)Unigine::Math::translate(-0.25, 0, 0); // sets first bone position/rotation/scale for the first frame frames[1] = (mat4)Unigine::Math::translate(0.25, 0, 0); // sets first bone position/rotation/scale for the first frame mesh->setAnimationFrame(0, frame_index, frames); frame_index = 1; // second frame frames[0] = (mat4)Unigine::Math::translate(-0.25, 0, 0); // sets first bone position/rotation/scale for the first frame frames[1] = (mat4)Unigine::Math::translate(0.7, 0, 0); // sets first bone position/rotation/scale for the first frame mesh->setAnimationFrame(0, frame_index, frames); staticMesh = ObjectMeshSkinned::create(mesh); //set animation staticMesh->setPosition(Unigine::Math::Vec3(0.0, 0.0, 1.1)); staticMesh->setLoop(true); staticMesh->play(); // Write here code to be called on world initialization: initialize resources for your world scene during the world start. return 1; } This is a really simple code that simply creates two bones on the plane and then animates them. Please check what part is missing. Please reply after happy holidays :) Link to comment
cash-metall Posted January 10, 2023 Share Posted January 10, 2023 Hello! everything is correct, but you need to specify which bones to animate: int nBone1 = mesh->addBone(); int nBone2 = mesh->addBone(); //.... Vector<short> bones; bones.append(nBone1); bones.append(nBone2); mesh->setAnimationBones(0, bones); // only 2 bone will be animated Vector<Math::mat4> frames; frames.resize(2); int num_frames = 60; mesh->setNumAnimationFrames(0, num_frames); for (int frame_index = 0; frame_index < num_frames; frame_index++) { frames[0] = (mat4)Unigine::Math::translate(-0.25, 0, 0); frames[1] = (mat4)Unigine::Math::translate(frame_index * 0.02, 0, frame_index* 0.02); // here 0 and 1 - it is not bone index. it is index in array of index of bone. (hmm....) // for save memory and not specify transformations for bones that are not involved in the animation. mesh->setAnimationFrame(0, frame_index, frames); } 1 Link to comment
KOVIAHN Posted January 11, 2023 Author Share Posted January 11, 2023 Dear cash-metall It Works. Thank you very much : ) 1 Link to comment
