carlos.vieira Posted December 20, 2022 Share Posted December 20, 2022 (edited) Hi, I'm not able to run examples with Vulkan... getting the following error... I'm using Unigine 2.16.1 (community) on Ubuntu 22.04... what am I missing? Thanks ---- GPU Detection ---- GPU 0: NVIDIA GeForce GTX 1650 4096 MB (Active) GPU 1: llvmpipe (LLVM 13.0.1, 128 bits) 2048 MB ---- System ---- OS: Linux 5.17.0-1020-oem x86_64 CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Frequency: 2670MHz Extensions: MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT Cores:8 Threads:8 System memory: 17983 MB Sync threads: 7 Async threads: 8 GPU: NVIDIA GeForce GTX 1650 Video memory: 4096 MB ---- Application ---- ---- System Proxy ---- ---- Render ---- VkWrapper::init(): can't load "libdxcompiler.so.3.7" library libtinfo.so.5: cannot open shared object file: No such file or directory Unigine fatal error: Can't initialize Vulkan wrapper Edited December 20, 2022 by carlos.vieira Link to comment
silent Posted December 20, 2022 Share Posted December 20, 2022 Hi Carlos, Is that a Linux running on a virtual machine or just regular PC with installed linux? Can you send us output from nvidia-smi command in terminal? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
carlos.vieira Posted December 20, 2022 Author Share Posted December 20, 2022 Hi Silent, It's a regular PC with installed Linux. Here's the output of nvidia-smi, thanks! $ nvidia-smi Tue Dec 20 14:38:36 2022 +-----------------------------------------------------------------------------+ | NVIDIA-SMI 525.60.11 Driver Version: 525.60.11 CUDA Version: 12.0 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 NVIDIA GeForce ... Off | 00000000:02:00.0 On | N/A | | 26% 32C P8 9W / 75W | 1225MiB / 4096MiB | 3% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 1984 G /usr/lib/xorg/Xorg 304MiB | | 0 N/A N/A 2164 G /usr/bin/gnome-shell 41MiB | | 0 N/A N/A 4042 G ...323811133061558650,131072 242MiB | | 0 N/A N/A 40874 G ./SdkBrowser 28MiB | | 0 N/A N/A 40937 C+G ...ne_project/bin/Editor_x64 604MiB | +-----------------------------------------------------------------------------+ Link to comment
silent Posted December 20, 2022 Share Posted December 20, 2022 Looks like libdxcompiler.so.3.7 library from the Vulkan SDK is looking for additional dependency (libtinfo5) which is missing on Ubuntu 22.04. You can try to fix this by installing libtinfo5: sudo apt-get update -y sudo apt-get install -y libtinfo5 This issue has been already resolved in the newest Vulkan SDK version: https://vulkan.lunarg.com/issue/view/63181d6e5df1129602e806f8 We probably need to update libdxcompiler.so in the upcoming 2.17 SDK update in order to resolve this issue completely. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
carlos.vieira Posted December 21, 2022 Author Share Posted December 21, 2022 Hey, thanks for hint Silent :) installing libtinfo5 did the trick. n browser 2 I've set the Vulkan API, but that does not seem to apply when running the editor, right? When we're using editor and run app from there, how can we rely on Vulkan API instead of OpenGL one? Link to comment
silent Posted December 21, 2022 Share Posted December 21, 2022 Editor is not working yet with DX12 / Vulkan since not all the objects are being ported to these APIs. More likely full Editor support would become available in 2.17 SDK release. It's not recommended to use Vulkan / DX12 in production in 2.16.1 since the integration is no yet final and it simply can give you crashes and visual artifacts. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
carlos.vieira Posted December 21, 2022 Author Share Posted December 21, 2022 Alright, thank you! Link to comment
