KOVIAHN Posted December 12, 2022 Share Posted December 12, 2022 (edited) Hello. I'm trying to create a GUI button, but it's not outputting. I created a window by overriding CustomSytemProxy. CustomWinAPIProxy::CustomWinAPIProxy(HWND hwnd) : CustomSystemProxy( SYSTEM_PROXY_MOUSE | SYSTEM_PROXY_KEYBOARD) And I created a window and set that window as the main window. *callback_ptr = Engine::get()->addCallback(Engine::CALLBACK_BEGIN_UPDATE, MakeCallback([callback_ptr, win_id = handle.win_id] { Engine::get()->removeCallback(Engine::CALLBACK_BEGIN_UPDATE, *callback_ptr); Memory::deallocate(callback_ptr); EngineWindowPtr engine_window = WindowManager::getWindowByID(win_id); if (engine_window) { engine_window->setNestedUsage(true); engine_window->setGroupUsage(false); engine_window->setMain(true); } } )); Rendering works normally, and mouse events are all implemented, but the GUI-related screen is not output. // creating a button widget and setting its caption WidgetButtonPtr widget_button = WidgetButton::create( Unigine::WindowManager::getMainWindow()->getSelfGui(), "Delete"); //ImagePtr image = Unigine::Image::create("omni_light_on.png"); //widget_button->setImage(image); // setting a tooltip widget_button->setToolTip("Delete object(s)"); // rearranging button size widget_button->arrange(); // setting button position widget_button->setPosition(100, 100); // adding created button widget to the system GUI Unigine::WindowManager::getMainWindow()->getSelfGui()->addChild(widget_button, Gui::ALIGN_OVERLAP | Gui::ALIGN_FIXED); box = Primitives::createBox(vec3_one); // Write here code to be called on world initialization: initialize resources for your world scene during the world start. Input::addCallback(Input::CALLBACK_IMMEDIATE_INPUT, MakeCallback(on_immediate_input)); Please tell me which part needs to be fixed. thank you Edited December 12, 2022 by KOVIAHN Link to comment
karpych11 Posted December 13, 2022 Share Posted December 13, 2022 Hello, Your code looks correct. I haven't been able to reproduce this behaviour. Is it possible to see at the complete implementation of the proxy and window creation? The reason may be that you are not using the SYSTEM_PROXY_WINDOWS flag. In this case, it will not be possible to create engine windows. You can only use custom external windows for rendering, but in this case you also need to implement GUI rendering yourself. Link to comment
KOVIAHN Posted January 6, 2023 Author Share Posted January 6, 2023 Dear karpych11 Currently, the program under development does not use the SYSTEM_PROXY_WINDOWS flag. So I think the GUI is not displayed. For reference, the IMGUI provided as a separate sample is output. We plan to implement necessary buttons by using IMGUI. As an additional question, can't I use the Visualizer class as well? If the Visualizer class doesn't render, it requires quite a bit of implementation. So, if it is not provided, I wonder if there is a plan to make it possible to use it in an external window through a future update. Thank you. Link to comment
karpych11 Posted January 9, 2023 Share Posted January 9, 2023 Hello, You can use the Visualizer for external windows. But most likely you will have to call removeSkipFlags(Viewport::SKIP_VISUALIZER) for the viewport. Link to comment
KOVIAHN Posted January 11, 2023 Author Share Posted January 11, 2023 Dear karpych11 It works. Thank you very much : ) Link to comment
