ShadowZelda Posted November 25, 2022 Posted November 25, 2022 Hi, This is not really a bug, but I think that the Hotkeys for Undo and Redo changed in the Unigine 2 [built in] Hotkey preset for 2.16 . 2.16: Undo (Crtl+Y), Redo (Crtl+Z) I'm very sure that that it was the other way round in 2.15.1 : Undo (Crtl+Z) and Redo (Crtl+Y). Since I can´t open both versions simultanously to be sure about it: Is this intentional or accidentally switched? I will switch it for my projects, so no problem at all, but I am curious if it was intended or not. Kind regards
silent Posted November 28, 2022 Posted November 28, 2022 ShadowZelda Yep, the reason of this is that we refactored input system and moved to scan-code based hotkeys where physical key position remains the same across multiple layouts. And it seems that this approach is not the best one for some built-in Editor hotkeys. The preset itself is not changed. Will see if we can fix this quick prior to the 2.16.1 release next month. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
silent Posted December 15, 2022 Posted December 15, 2022 As a partial fix in 2.16.1 we introduced QWERTZ built-in preset. Later in 2.17 it would be loaded automatically on Editor start-up (this option can be disabled). Hotkeys management would be still based on scan codes. QWERTZ preset remaps two buttons locations and even if you will change input language to Eng (QWERTY), Ctrl+Z would still be located at the exact same place where it located in QWERTZ keyboard. We are also wondering how AZERTY users are using undo/redo, since if movement would be ZQSD (WASD) undo would be mapped to Ctrl+W. Don't know if that's common expected behavior or not :) 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
ashtorak Posted March 27, 2023 Posted March 27, 2023 On 12/15/2022 at 3:24 PM, silent said: As a partial fix in 2.16.1 we introduced QWERTZ built-in preset. Later in 2.17 it would be loaded automatically on Editor start-up (this option can be disabled). Hotkeys management would be still based on scan codes. So to understand this, currently when I start up the editor with QWERTZ selected, it shows it as the selected preset, but you have to re-select it to actually get the undo keys switched. This will be automatic in the future or is this a bug?
silent Posted March 27, 2023 Posted March 27, 2023 Yes, you need to select this preset manually in 2.16.1 (and probably re-select too). Should be fine in 2.17. 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
