libAppVive_x64.so not found on Ubuntu 22.04
I'm trying to make VR work with Unigine on Ubuntu 20.04 but when I run the app with -extern_plugin "AppVive" parameter, following error appears:
---- Plugins ----
Loading "libAppVive_x64.so"...
Unable to init VR runtime: vrclient Shared Lib Not Found (102)
Plugins initialization: 206ms
Where does this library come from? Does it come from HTC Vive libraries or is it Unigine internal library? What needs to be installed on Ubuntu to make it work?
Thanks,
Radim
rada-wolf
This vrclient Shared Lib Not Found (102) doesn't look like it's related to the UNIGINE, but rather the SteamVR runtime libs could not be loaded. Can you run other SteamVR (OpenVR) compatible apps without this error?
Did you have SteamVR and Steam (with 32 and 64 bits runtimes) installed correctly? If so, we need to understand what exact steps did you make before this actual error occurred and try to replicate on our side.
If you are using latest 2.16.x SDK you need to use -extern_plugin "OpenVR" instead of -extern_plugin "AppVive". This plugin was renamed recently. Maybe that's also causing some issues.
