Write code questions using Json Class(USC).
How do I get array elements using Json Class(USC)? I have an error trying to use the getChild(int num, variable var) function.
our json parser currently support only vec2/vec3/vec4 as an array types.
Here an example how you can access this json file
  "array_test": [ 0, 0, 1 ]
via Unigine Script:
	Json j = new Json();
	if (j.load("test.json") == false)
		return;
	Json a = j.getChild(0); // Get "array_test" child
	vec3 v = a.getVec3(); // Get it's value
	log.message("%f %f %f\n", v.x, v.y, v.z);
Best regards.
  • Thanks 1
