Tessalator Posted October 9, 2022 Share Posted October 9, 2022 Is there an easy/built-in way to prevent clicking on a UI item from passing through to the World? -If I have an Input.MOUSE_DOWN event (new Input System) and I create a pop-up window, actions like dragging the window or clicking in a textbox fire the mouse event. This is expected, but not always desired behavior. Is there a (simple) way to detect UI hits and prevent other events from firing? Link to comment
silent Posted October 10, 2022 Share Posted October 10, 2022 Tessalator Can you show us which windows are your createing and doing dragging? Simplified code-snippet would be great to better understand the situation. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Tessalator Posted October 10, 2022 Author Share Posted October 10, 2022 Hi Silent, In the code below the `Mouse` function will get called on any MOUSE_DOWN. In this example I would be placing objects in the world at the mouse coordinates. I may pop up a config window for the objects being placed. (I just use a fixed window here) If the window is up and I click on the GUI element/Widget I don't want the placement code to run. I'm looking for a way to do this without having to mask a lot of things or carry state variables around. static class Program { public static IntPtr clickPtr; static WidgetWindow window = new WidgetWindow("Modes", 4, 4); [STAThread] static void Main(string[] args) { Engine.Init(args); clickPtr = AddCallback(CALLBACK_INDEX.MOUSE_DOWN, Mouse); window.Flags = Gui.ALIGN_OVERLAP | Gui.ALIGN_LEFT; window.Width = 320; window.Arrange(); Gui.Get().AddChild(window); void Mouse(MOUSE_BUTTON button) { // if (clicked_on_widget) return PlaceNewObjectInWorld(...); } Engine.Main(); Engine.Shutdown(); } } Link to comment
karpych11 Posted October 11, 2022 Share Posted October 11, 2022 Hello, In version 2.16 the GUI has a GetUnderCursorWidget() method to get the widget under the cursor. You can try to use it in this case. public static IntPtr clickPtr; static WidgetWindow window = new WidgetWindow("Modes", 4, 4); public override bool Init() { clickPtr = Input.AddCallback(Input.CALLBACK_INDEX.MOUSE_DOWN, Mouse); window.Flags = Gui.ALIGN_OVERLAP | Gui.ALIGN_LEFT; window.Width = 320; window.Arrange(); Gui.GetCurrent().AddChild(window); return true; } void Mouse(Input.MOUSE_BUTTON button) { if (Unigine.Console.Active || Gui.GetCurrent().GetUnderCursorWidget() != null) return; PlaceNewObjectInWorld(...); } 1 Link to comment
Tessalator Posted October 11, 2022 Author Share Posted October 11, 2022 @karpych11 This works for most widgets but doesn't seem to pick up layout type widgets like `WidgetHBox`. Is that by design? Link to comment
karpych11 Posted October 13, 2022 Share Posted October 13, 2022 Yes, this method doesn't return the layout widgets (VBox, HBox, GridBox) and also ignores the console widget, the profiler widget, and widgets inside the EngineWindow as a separate window and as a group. Otherwise, we would always have a widget under the mouse, since the Gui contains the root VBox, and some widgets use layouts internally as containers. Link to comment
