2.16b Input::getAndClearSysKey replacement of 2.15.1 App::clearKeyState?
Updating our code to 2.16.b, it seems replacement of App::clearKeyState is Input::getAndClearSysKey.. or?
I would expect same behavior, reading once the key state.. but it seems not to be the case.
Can you check / suggest proper way?
Regards,
Charles
Function analogs from App have been moved to Input only for backward compatibility in engine subsystems. It has now been completely removed. Their use has become difficult due to event-based buffered input. Also, these functions could change the input processing logic depending on the order of the call. The isKeyDown, isKeyPressed, and isKeyUp functions remain for key processing. You can also handle keyboard events using callbacks and an event filter.
Thanks for precision.
So.. if I want one action and only one action when the user press key 'd'... i shouldn't use Input::getAndClearSysKey(Input::KEY_D) but Input::isKeyPressed(Input::KEY_D) right?
Or should I setup callbacks? Any doc pointer? Or an example maybe?
Regards,
Charles
RIght now you need to write custom app logic for that because if isKeyDown triggers in the current frame, all the conditions like if (Input::isKeyDown(Input::KEY_D)) would be triggerted as well. The same behavior with isKeyPressed and isKeyUp
For example, simple way to achieve a single action when key D is down:
is_d_key_down = Input::isKeyDown(Input::KEY_D); // store key value before each frame
if (is_d_key_down)
    is_d_key_down = false;
    // key logic
Or complex filter implementation:
int input_events_filter(InputEventPtr &e)
	InputEventKeyboardPtr key = checked_ptr_cast<InputEventKeyboard>(e);
	if (key && key->getAction() == InputEventKeyboard::ACTION_DOWN)
		if (key->getKey() == Input::KEY_D)
			// process event and don't pass it to engine
			// call may not be on the main thread
			// your key logic
	return 0;
int AppSystemLogic::init()
	Input::setEventsFilter(input_events_filter);
int AppSystemLogic::update()
	if (Input::isKeyPressed(Input::KEY_D))
		// unreachable state because we are discarding events in the filter
isDown / isUp - simple flag (for 1 frame) that indicates if button is down or up. isPressed - indicates if button is pressed and stores info in-between multiple frames.
Hope that helps :)
  • Thanks 1
